Activity › Forums › VEGAS Pro › Best software to re-encode for Vegas to use
  • John Rofrano
    August 31, 2014 at 10:09 am
    [Scott Francis] “Vegas is seeing this a 1920×1088 now instead of 1920×1080 as it did prior to re-muxing. “
    I’m not seeing this. I used AviDemux 2.6 64-bit using the COPY, COPY, MP4 MUXER, settings and Vegas Pro sees the file as 1080.
    Here is what MediaInfo says:
    Overall bit rate mode : Variable
    Overall bit rate : 20.2 Mbps
    Writing application : Lavf54.63.104
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 31s 122ms
    Bit rate mode : Variable
    Bit rate : 20.0 Mbps
    Maximum bit rate : 39.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Original height : 1 088 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.321
    Stream size : 74.1 MiB (99%)
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 31s 104ms
    Bit rate mode : Constant
    Bit rate : 253 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 962 KiB (1%)
    Language : unk
    QuickTime Player also shows it as 1920×1080. Notice that MediaInfo says Original height : 1 088 pixels so maybe it was captured at 1088 but the MP4 file from both Vegas Pro 13.0 and AviDemux 2.6 says 1080 on my Windows 7 computer.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Scott Francis
    September 1, 2014 at 6:15 pm
    This was totally my fault, I selected a file that was created by Ezencoder and not the original. The original worked fine!! Sorry for any confusion.
    One last thing, any type of batch conversion in Avidemux?
    Thanks so much again!!
    Xavier (Scott) Francis
    Mind’s Eye Audio/Video Productions
  • John Rofrano
    September 1, 2014 at 9:15 pm
    [Scott Francis] “One last thing, any type of batch conversion in Avidemux?”
    Unfortunately no. You would have to convert them one at a time. 🙁
    ~jr
  • Scott Francis
    September 2, 2014 at 12:37 am
    Thanks again for all your help John, I guess I will have a little work cut out for me then!!
    Best!
  • John Rofrano
    September 2, 2014 at 2:20 am
    [Scott Francis] “I guess I will have a little work cut out for me then!!”
    Yea, if you had Mac you could use Compressor to batch render these. If Adobe Media Encoder can read them you could do the same on the PC. Of course if you had a Mac you could just edit them in Final Cut Pro X without any re-encoding because the original file edits smoothly in FCP X (which I find myself using a lot these days). It’s just too bad Vegas Pro can’t handle them. 🙁
    ~jr
  • Scott Francis
    September 2, 2014 at 12:38 pm
    I have a Mac as well, and both Compressor and Media encoder. However, re-muxing takes way shorter time than either of those for the length of some of the clips (2 hrs).
    Thanks again for all your help!
  • John Rofrano
    September 3, 2014 at 12:03 pm
    Yea, if remixing works for you then that is definitely the best approach. Not only for time savings but for quality savings as well. Glad I could help.
    ~jr
Page 2 of 2
