Activity Forums Apple Final Cut Pro Legacy Best setup for edit for web
  • Best setup for edit for web
    Posted by Juan Carlos aguirre on April 28, 2009 at 8:36 pm
    Hello All.
    We normally edit for broadcast, now we have a project that will be distributed by web and interactive kiosks. Does anyone can advice what will be a good work flow. For me seams that all will be on a progressive base (shoot, edit, compress and deliver always using progressive setup) instead of go interlace and the convert to progressive, considering that this will never be broadcast, but we are not sure and need some help.
    Sorry if this is a very dumb question, but its a new experience for us and don’t want to mess it out.
    Any direction is very welcome.
    JC
    Juan Carlos Aguirre
    HTV Studio
    http://www.htvstudio.com
    Juan Carlos aguirre replied 17 years ago 3 Members · 5 Replies
  • Chris Poisson
    April 28, 2009 at 9:32 pm
    Juan,
    Because the best way to evaluate color and images is on an NTSC monitor, working as though for broadcast is certainly advantageous. There are several ways to deinterlace later many of which work superbly. Compressor is one, Episode another. We do a ton of work for the Internet and all of it starts interlaced. We do work in 30f which is kind of a fake progressive, but we know what it will look like because we are editing and color correcting on a proper monitor.
    Have a wonderful day.
  • Juan Carlos aguirre
    April 28, 2009 at 9:54 pm
    Thanks Chris for your fast respond.
    Any suggestion on settings for compressor to get a good final output. Seams that they will need FLV (Flash) files for interactive kiosks.
    JC
    Juan Carlos Aguirre
    HTV Studio
  • Chris Poisson
    April 28, 2009 at 11:28 pm
    Well, I don’t think you can do FLVs in Compressor. But, you can deinterlace your shows in FCP or, with JES Deinterlacer, which is fantastic. Then you can go in Flash and make your FLVs.
  • Andrew Kimery
    April 29, 2009 at 1:46 am
    If you can go progressive, go progressive. No fields to worry about, it compresses cleaner, and deinterlacing always toss picture info away (the question is just how much). If you already have a bunch of money invested in an interlaced workflow then you’ll have to do your own cost/benefit analysis, but if you are starting from square one progressive is better option, IMO.
    -A
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
    April 30, 2009 at 3:22 am
    Actually you can, using the Quicktime Export Components, and then select Flash Video FLV as an option.
    I don’t remember if I install a plugin for quicktime but I can export FLV from compressor,
    Andrew, we will shoot on P2 cameras that i know can shoot progressive 720p and then edit on FCP all progressive, what do you think ?
    JC
    Juan Carlos Aguirre
    HTV Studio
