Activity › Forums › AJA Video Systems › Best setup for audio with Aja IO
  • Best setup for audio with Aja IO
    Posted by Peter Dewit on October 26, 2007 at 1:15 pm
    SO I’m working with some audio sensitive material and am a little confused on the best way to deal with audio using the IO. I have both computer speakers and a set of a rolands hooked directly into the IO box. I’m monitoring via composite to a broadcast monitor.
    Someone else was editing on this system without realizing the setup and used the computer speakers and syncing it to the broadcast monitor. This is obviously going ot be slightly out of sync. I was wondering if there’s a concrete number of frames the sync would be off by so I can correct it. In the long term I should always trust the rolands and broadcast monitor for verifying sync right?
    Also is there a way to tweak the playback in FCP’s displays to match the broadcast monitor?
    Andrea Stewart replied 18 years, 10 months ago 3 Members · 2 Replies
