Activity › Forums › Adobe After Effects › Best settings to render a 7 minute long slideshow/animation composition?
  • Best settings to render a 7 minute long slideshow/animation composition?
    Posted by Rafael Ribeiro on May 22, 2014 at 1:27 pm
    I just woke up to this huge .mov file with 10Gb. The composition has approximately 7 minutes.
    I used the animation codec for quicktime files.
    How should I go about this? This can’t be right, there are only 200 photos on that slideshow with lots of animations/transitions.
    I actually need a quick solution using the already gigantic file. Maybe rendering that file with new settings will be faster and, hopefully, compress it?
    Composition settings:
    720×480 pixels – D1/DV NTSC Widescreen (1,21)
    06m53s
    frame rate: 29,97
    operating system:
    OS X
    2,66 GHz Intel Core i7
    8 GB 1067 MHz DDR3
    NVIDIA GeForce GT 330M 512 MB
    AECS6
    Also, I’ve been using After Effects now for almost 4 years, and the codec / rendering is a process that I’m not too familiar with. Could you guys also point me into a good tutorial or a good read ( explaining with details) about which codecs to use?
    Thanks a lot.
    Rafael Ribeiro
    Rafael Ribeiro replied 12 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Todd Kopriva
    May 22, 2014 at 2:21 pm
    Start with this FAQ entry:
    https://forums.adobe.com/thread/729526
    After Effects team blog
  • Daniel Waldron
    May 22, 2014 at 4:30 pm
    If you’re looking for small file size, I would create an H264 file. You can drop your 10GB file into Adobe Media Encoder and choose from their list of web presets to keep it simple.
    It’s best to find out if whoever you’re delivering it to has a preference though. Depending what it’s for, there could be specific format requirements. Either way, creating a master Animation file and exporting delivery files from AME is not a bad idea. This way, you can create multiple formats from one file without After Effects having to chug through everything multiple times.
  • Rafael Ribeiro
    May 22, 2014 at 6:51 pm
    Dave LaRonde
    I have done lots of renders. But mostly for small files ( 30 secs vignettes); so I’d always go with .avi and .mov files that would be 1Gb tops.
    Daniel Waldron
    I rendered the 10Gb file into a H264 one. It reduced the size to 350Mb. It works for me ( it kept the video quality and a reasonable size).
    I guess I need to learn more about codecs and preferences. Usually I don’t have to deal with that with such short videos. Living and learning.
    Thanks everyone.
  • Rafael Ribeiro
    May 23, 2014 at 8:49 pm
    Originally it is going to be shown in a presentation with a projector in a big screen. After that my client probably wants to upload it to youtube.
  • Daniel Waldron
    May 23, 2014 at 10:37 pm
    In that case, H264 is a great way to go.
  • Rafael Ribeiro
    May 23, 2014 at 11:21 pm
    Great. Thanks a lot for the help!
  • Rafael Ribeiro
    Okay. Thanks for the help!
