Activity Forums Adobe Premiere Pro Best Settings to import Native 525 interlaced 29.97 AJA codec 10 bit uncompressed masters in CS5.
  • Best Settings to import Native 525 interlaced 29.97 AJA codec 10 bit uncompressed masters in CS5.
    Posted by Steve Mac kenzie on April 24, 2012 at 2:45 am
    This is the note from the post house. “These are all 525 interlaced masters and digitized as that. So the ingest was native 525 29.97 AJA codec 10 bit uncompressed. Your timeline will have to match these settings. As with all telecine at that time, there was no 23.98 (24P) transfers. Hence all film is 3:2 pulldown and should be constant cadence although it might not be.”
    I have tried everything I can think of and burned test clips to DVD’s as well. The best I have gotten was jumping over to progressive because the interlacing is a mess otherwise. These clips are all .mov. 720 X 486, when I drag them on the timeline it makes them progressive but the titles still jump. This is a turn key PC based system.
    Any Ideas? Thanks!
    Steve Mac kenzie replied 14 years, 4 months ago 2 Members · 2 Replies
  • Jude Poyer
    April 24, 2012 at 1:37 pm
    This may well be way above my pay grade (so forgive me if I’m being dumb). Have you tried creating a project (but not a sequence), importing your assets, then selecting a clip and (right click in Windows) choosing “new sequence from clip”. That should create a sequence matching the compression, frame size, field order etc of your footage.
  • Steve Mac kenzie
    April 27, 2012 at 7:29 pm
    I appreciate your thinking on this. However Adobe is seeing it wrong when it makes a sequence. Usually this would work just fine!
    Thank You for your input!
