Activity Forums Apple Motion best settings: Motion/Compressor to Youtube
  • best settings: Motion/Compressor to Youtube
    Posted by Joseph Shelley on March 24, 2011 at 9:16 pm
    Hi all,
    Wondering if anyone can suggest settings for Motion and Compressor content that is intended for Youtube.
    Been reading up on how to compress Final Cut footage for Youtube. None of the suggested settings seem to come out with Motion footage. Main issue is jagged edges around objects, almost like they were interlaced. Also some compression artifacts, especially in highlights.
    here are my settings:
    Name: YouTube HQ H264 HD 1080
    Description: 1080*1920 full res, square pix
    File Extension: .mov
    Estimated file size: unknown
    Audio Encoder
    AAC, Stereo (L R), 44.100 kHz
    Video Encoder
    Format: QT
    Width: 1920
    Height: 1080
    Pixel aspect ratio: Square
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls On:
    Retiming: (Best) High quality Motion Compensated
    Resize Filter: Statistical Prediction
    Deinterlace Filter: Best (Motion Compensated)
    Adaptive Details: Off
    Antialias: 0
    Detail Level: 0
    Field Output: Progressive
    Codec Type: H.264
    Multi-pass: On, frame reorder: On
    Pixel depth: 24
    Spatial quality: 100
    Min. Spatial quality: 25
    Key frame interval: 12
    Temporal quality: 50
    Min. temporal quality: 25
    Fast Start: on
    About to try this instead:
    Estimated file size: 4.29 GB/hour of source
    Audio Encoder
    Video Encoder
    Format: QT
    Width: 1920
    Height: 1080
    Crop: None
    Padding: None
    Frame Controls On:
    Deinterlace Filter: Better (Motion Adaptive)
    Antialias: 0
    Detail Level: 0
    Codec Type: H.264
    Pixel depth: 24
    Spatial quality: 75
    Average data rate: 10.24 (Mbps)
    Maximum data rate: 10.24 (Mbps)
    Fast Start: on
    Andy Neil replied 15 years, 5 months ago 3 Members · 5 Replies
  • Jeff Greenberg
    March 25, 2011 at 10:46 am
    I know this is a silly question: have you tried the youtube preset under the File> share menu (or are you using Motion 3?)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Joseph Shelley
    March 25, 2011 at 2:24 pm
    Hi Jeff,
    I’m still using Motion 3. You don’t happen to have the settings handy in the inspector, do you? if so, is there any way you could copy and paste them for me, so I can check them out?
    Any other advice would be welcome.
    Thanks for the response,
    -Joe
  • Jeff Greenberg
    March 25, 2011 at 3:46 pm
    Basically, it’s an 8mb h.264 in a QuickTime wrapper.
    Best,
    Jeff G
  • Joseph Shelley
    March 25, 2011 at 5:05 pm
    Awesome,
    Thanks for the screenshot! I’ll see if I can glean anything from it.
    Cheers,
    -joe
  • Andy Neil
    March 26, 2011 at 4:05 pm
    Well, what are your source settings? What are you starting with? I use a preset similar to your first setting (frame controls are typically unnecessary for a you tube upload). I do set the bit rate to between 3000 and 6000 kbs.
    However, it matters a little what your Motion settings are as well. What is your frame size and frame rate?
    Andy
    https://www.timesavertutorials.com
