Activity › Forums › Adobe After Effects › Best Settings / Hardware Setup Config for my Workstations? (Plus Nucleo Pro 3)
  • Best Settings / Hardware Setup Config for my Workstations? (Plus Nucleo Pro 3)
    Posted by Eric Richner on September 1, 2010 at 5:52 pm
    I’m new to After Effects (and Premiere) and have been scouring the internet on how to optimize my workflow from the beginning. I have also looked into adding Nucleo Pro 3 to my After Effects workflow as it seems to be very useful in reducing rendering times.
    My main Workstation/Media Center (PC #1):
    OS: Windows 7 x64
    CPU: Quad-core Intel i7 920 2.6ghz overclocked to 3.8ghz with HyperThreading
    RAM: 8GB DDR3 1600
    GFX: Nvidia GTX 460 1GB (Gigabyte)
    DRIVES:
    OS Drive – 1TB 7200rpm 32MB Cache SATA 3GB/S (Western Digital Caviar Black)
    Scratch Disk – 160GB 7200rpm 8MB Cache (Western Digital AV)
    Backup – 8TB RAID5 (Hardware) USB3/ESATA 4-Bay External Enclosure on another WIN7x64 PC connected directly via Gigabit Ethernet
    MONITORS: All Calibrated w/ X-rite i1 Display
    2 x 21.5in 1920×1080 LCD (Compaq)
    My second Workstation (PC #2):
    CPU: Six-core AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz
    RAM: 8GB DDR2 1333
    DRIVES:
    OS – 300GB 10000rpm 16MB Cache SATA 3gb/s (Western Digital Velociraptor)
    Scratch Disk – 120GB 10000rpm SATA 1.5gb/s (Western Digital Raptor, 5yrs old)
    Backup – 8TB USB3.0 RAID5 (Hardware) 4-Bay External Enclosure
    1 x 23in 1080p IPS LCD (NEC)
    Note:
    I do plan on upgrading the OS Drives on both PC’s to 160GB or 256GB SATA III 6gb/s SSD drives within the next two months (and will get duplicate drives to put in a RAID a few months after that). I also will be bumping up the RAM on PC #2 to 16GB DDR 1600 and adding a Nvidia GTX 460 1GB graphics card.
    I have After Effects and Premiere Pro CS5 installed on the MAIN OS drive for both workstations. (Also Cinema 4D, Maya, & 3DS Max 2011).
    I would love some advice as to how I should setup my After Effects, Premiere, and Nucleo Pro 3 for optimal performance.
    After Effects / Premiere on BOTH:
    1) Which drives should I run my projects off of? OS Drive or Scratch Disk?
    2) Should I have my Media Cache set to my internal Scratch Disk?
    3) Would having the Projects and the Cache on the same drive affect the performance (if it was all on the OS drive or the Scratch Disk)?
    4) Amount of RAM to allocate to the programs?
    For PC #2:
    1)Should I use the internal Scratch Disk or just use my 8TB USB 3.0 (up to 5.0gb/s connection) External RAID5 as the Media Cache + Scratch Disk location?
    Regarding Nucleo Pro 3:
    Depending on the best settings recommended for the questions above, should I have the following:
    1) Root cache directory for Spec Preview, Render, Precomp Proxy set on the OS drive or Scratch Disk?
    2) Should I “Enable cache creation for Spec Preview”?
    3) Which is the fastest/highest quality option for: (a) Render Options (b) Fast Preview Options
    3) Any other settings to look in to?
    Thanks for taking the time to read this long post, I appreciate in advance any advice suggested.
    Eric
    Walter Soyka replied 16 years ago 3 Members · 5 Replies
  • Walter Soyka
    September 1, 2010 at 6:54 pm
    In general, I’ll second Dave’s recommendation to get as much RAM as possible.
    I’ll also point out that those calibrators are intended for print work. If you want accurate monitoring of video, you should invest in an AJA or BMD card and a broadcast monitor.
    You might consider adding another drive to both machines for renders. In some cases, this will give you a speed boost since one drive is not doing all the reading and writing.
    Finally, I’ll point out a couple resources you may not have seen:
    Improve performance in After Effects
    Video Cards for Adobe Premiere CS5 (haven’t tried this)
    [Eric Richner] “1) Which drives should I run my projects off of? OS Drive or Scratch Disk?”
    I don’t think this matters as much in 2010 as it did in 2000. History suggests running your projects off the OS drive, but I run projects and media off a fast RAID without any trouble.
    [Eric Richner] “2) Should I have my Media Cache set to my internal Scratch Disk?”
    No. Treat the cache like footage.
    [Eric Richner] “3) Would having the Projects and the Cache on the same drive affect the performance (if it was all on the OS drive or the Scratch Disk)”
    Your disks spend a lot more time accessing media than they do the project files. I don’t think this will have a noticeable impact on performance.
    [Eric Richner] “4) Amount of RAM to allocate to the programs?”
    See Dave’s response — as much as possible. AE is 64-bit in CS5, and it can use however much memory you can cram into your system.
    [Eric Richner] “For PC #2:
    1)Should I use the internal Scratch Disk or just use my 8TB USB 3.0 (up to 5.0gb/s connection) External RAID5 as the Media Cache + Scratch Disk location?”
    I use my RAID. I’d suggest you do the same.
    [Eric Richner] “Regarding Nucleo Pro 3:
    3) Any other settings to look in to?”
    I used to use Nucleo Pro specifically for its spec render feature. Regular multiprocessing in AE is pretty good, so I’ve stopped using NP.
    If you do choose to use it, treat the cache files like footage.
    Walter Soyka
  • Eric Richner
    September 1, 2010 at 7:24 pm
    Yea, thats the one bottleneck I can tell off the back. Unfortunately there are no AMD motherboards that can support 24gb of RAM with USB3 and SATA 6gb/s built-in right now, the only ones with that technology available support a maximum of 16GB of RAM.
    I am about to upgrade my motherboard with one that does have SATA 6gb/s and USB 3.0 built-in ($109), add 2x 4GB (8GB) 1600 RAM ($239), and get an all-in-one water cooler CORSAIR H70 ($107).
    That’ll set me back around $470ish with tax and shipping. Currently have only $500 left in my budget of $7,000 for all the new equipment I’ve purchased to start up my own production company.
    PS If anyone is interested in buying a Quad-Core 2.6ghz AMD CPU + Aftermarket Cooler/Fan, Motherboard, and 4GB performance ram; let me know 🙂
  • Eric Richner
    September 1, 2010 at 7:35 pm
    Thank you for the advice regarding the RAM and which disks to utilize.
    My biggest issue is staying within my budget, but if planned right, I will be able to get them most out of it.
    Here are some links regarding using Graphics Cards in the new CS5 Premiere:
    GTX 480 performance in Adobe Premeire Pro CS5
    You can essentially use any GTX 240 and up card with more than 768mb Video RAM; all you have to do is apply this simple hack:
    Premiere CS5 – Mercury GPU Acceleration on the cheap
    Which works these cards:
    GeForce GT 240
    GeForce GTS 240
    GeForce GTX 260
    GeForce GTX 275
    GeForce GTX 285m
    GeForce GTX 295
    GeForce GTX 470
    GeForce GTX 480
    So for $229 I got myself a 1GB GTX 460 and used the hack and BAM the Mercury Engine works like a charm.
  • Bob Gilman
    September 30, 2010 at 11:37 pm
    Hello from sunny Seattle….right.
    I just had a new system built by a pro. He suggested a GeForce GTX 460 768 for my graphics card. What is the opinion on the forum for this product in relation to AE? Has anybody had a problem with this card?
    Bob
  • Walter Soyka
    October 1, 2010 at 12:31 pm
    [bob gilman] “I just had a new system built by a pro. He suggested a GeForce GTX 460 768 for my graphics card. What is the opinion on the forum for this product in relation to AE?”
    Relative to AE, it doesn’t matter. After Effects renders on the CPU, not the GPU. AE doesn’t care which graphics card you have.
    Premiere Pro CS5, on the other hand, features the new Mercury Playback Engine which does use qualified NVIDIA graphics cards. Version 5.0.2 adds support for the NVIDIA GTX 470, so that’s the card I’d go for. The GTX 460 is not supported.
    Walter Soyka
