Activity › Forums › Compression Techniques › Best settings for Sorenson Squeeze / iDVD
  • Best settings for Sorenson Squeeze / iDVD
    Posted by Simon Miller on July 5, 2008 at 12:30 am
    Hi everyone,
    Newbie on here, and hoping someone can help!
    I’ve got a sequence I need to get from Avid Adrenaline into iDVD via Sorenson Squeeze this week. It’s a PAL 16:9 standard definition project. The sequence itself is only 30′ long so I’m hoping I can do it in pretty high quality.
    Does anyone know the best settings to use in Squeeze to get the best results into iDVD? I know iDVD is limited in the formats it can take in.
    Any help would be much appreciated! I’m just not sure which format to get Squeeze to export to. I have googled around for what seems like hours and have done a search in forums here but can’t seem to find the answer.
    Thanks in advance!
    Simon Miller replied 18 years, 2 months ago 2 Members · 2 Replies
  • Daniel Low
    July 6, 2008 at 9:31 pm
    What format are you working with?
    HDV? DVCPRO HD? XDCAM?……..
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Simon Miller
    July 8, 2008 at 5:54 pm
    I got it worked out through trial and error in the end actually – just chose a Quicktime HD720 export setting, selected 16:9 in the drop down menu at the top of the app, and then changed the HD720 settings to export at 720 x 576.
    Worked a charm, but thanks for getting back to me!
    Simon
