Activity › Forums › VEGAS Pro › Best settings for render HDV 1440×1080 25 fps?
  • Best settings for render HDV 1440×1080 25 fps?
    Posted by Alexey Protasov on August 28, 2011 at 4:35 pm
    It will be very appreciated if someone can help – how to render HD file in Vegas?
    Before i always worked with AVI DV template for 720×576.
    Now my project settigs is: 1440×1080, 25fps, Ratio 1,333, progressive.
    What is the best render settings? I’m on Vegas 10 32-bit. I want to get final file AVI 1440×1080, not very compressed, but not too big.
    Project length is 5:49, and i want to get it not bigger than 3-4 Gb. How can i render for the best quality/size, which codec will be the best?
    And should i tick “do not letterbox” when rendering? I’d like player show the real proportional video afterwards.
    John Rofrano replied 15 years, 1 month ago 2 Members · 3 Replies
  • John Rofrano
    August 28, 2011 at 10:31 pm
    I don’t believe you want AVI. HDV is MPEG2. I would render back to MainConcept MPEG2 using one of the HDV templates that match your source.
    Also, how are you going to deliver the file? It you plan to burn it to Blu-ray you want to use one of the Blu-ray templates instead.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Alexey Protasov
    August 29, 2011 at 2:38 pm
    Thank you so much, John!
    I made it as .m2t file with MainConcept MPEG2 and it works perfectly!
    I’m very new with HDV, but i’ve got so short time to make this video, so now i know a lot 😉
    Thank you!
  • John Rofrano
    August 30, 2011 at 1:48 am
    You’re welcome. Glad I could help.
    ~jr
