Activity › Forums › RE:Vision Effects › Best settings for my file
  • Shin Kurokawa
    August 2, 2005 at 1:05 pm
    I can tell you that because the action is ‘fast’ and
    the frame differences are huge, it’d be necessary
    to guide Twixtor’s motion detection using some
    manual tracking (in Twixtor Pro) at least to separate
    certain ‘areas’ from each other. Plus the clip has
    been captured with a fairly long exposure time
    (hence motion blur). So there’s no one magical
    setting that would track everything fully, and
    the manual tracking work would be the thing to do.
    You could easily spend several hours to set up polys
    for something like this. If you’re in a hurry, you
    may want to concentrate on the hands and fingers
    making them the ‘foreground’ objects, since
    there are less details and interest in his gi.
    His face would be easy to track, except where his
    hands go ‘in the foreground’ and when he starts to
    rotate towards the camera.
    Perhaps another approach might be to extend where there’s
    less frame differences and quicken where there are –
    to exagerrate both the ‘fast’ parts and ‘slow’ parts –
    using frame-number speed control. For such a speed
    ramp, the motion blur compensation would be quite
    effective since it will exaggerate blur where
    action is ‘fast’ and subtract it where the action is
    ‘slowed down’.
    HTH
    -Shin
  • Rick Mcnealy
    August 2, 2005 at 3:46 pm
    good tips…thanks
