Activity Forums Apple Final Cut Pro Legacy best settings for live capture EX-3
  • best settings for live capture EX-3
    Posted by Matt Shires on March 10, 2009 at 5:53 pm
    Hi All,
    Here’s the questions
    (1)
    I’m live capturing of an EX-3 over an SDI straight into a Blackmagic Multibridge Extreme, the camera will be shooting 720 25p. What’s the best quality setting for this that I can handle with a 400mb/s raid, Prores HQ, 10-bit, 10bit 444 RGB? I’m a tad confused.
    (2)
    What is the pixel dimension of HDTV 720 25p, apparently FCP is stating it’s square but is that true, I’m just a bit uncertain. Does it change with different codecs?
    (3)
    Finally what are the benefits of square pixels as opposed to rectangles?
    Much Thanks for any help or suggestions.
    Matt
    Walter Biscardi replied 17 years, 5 months ago 4 Members · 4 Replies
  • Chris Borjis
    March 10, 2009 at 6:12 pm
    best quality?
    1280×720 10-bit uncompressed
    great quality at a reduced file size?
    1280×720 ProRes HQ (it’s 10-bit only)
  • Rafael Amador
    March 10, 2009 at 6:15 pm
    Hi Matt,
    I don’t think you will be able to capture 10b RGB. Files are bigger than 10b Unc.
    i would go for Proress HQ.
    Your capture preset must be 1280×720 Square pixes.
    HD pixels are for DVCProHD and HDV.
    rafael
    http://www.nagavideo.com
    (and here some clips for the friends: https://www.vimeo.com/2694745 )
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Matt Shires
    March 16, 2009 at 1:46 pm
    Is it possible to live capture with an animation codec from the HD-SDI output of the EX-3?
  • Walter Biscardi
    March 16, 2009 at 1:52 pm
    [matt shires] “Is it possible to live capture with an animation codec from the HD-SDI output of the EX-3?”
    No. You can capture to Uncompressed 10bit HD if you really want to. I would just capture to ProRes though.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
