Activity Forums VEGAS Pro Best settings for blu-ray from vegas output
  • Best settings for blu-ray from vegas output
    Posted by Jeffrey Ellis on December 18, 2009 at 9:10 am
    I actually just mis-posted this:
    I’m trying to burn the project in DVDA. A while ago, John Rofrano had recommended the following output from vegas:
    To render the video:
    From the Vegas menu select File | Render As…
    In the Render As dialog under Save as type: select Sony AVC (*.mp4;*.m2ts;*.avc)
    Under Template: select Blu-ray 1920×1080-60i, 16 Mbps video stream
    Click the Save button
    But I see that while the extension is .avc, the video is actually AVCHD. Does this mean the output is in fact AVCHD, by any chance?
    If not, can you tell me the optimal settings to output to Blu-Ray in DVDA?
    Thanks again.
    Jeffrey Ellis replied 16 years, 8 months ago 2 Members · 4 Replies
  • John Rofrano
    December 18, 2009 at 10:34 am
    Yes, this is AVCHD and if your camera shoots AVCHD (which I believe is the reason I told you to use this template) and you don’t add any FX or otherwise alter the video, Vegas will just copy the source video unchanged with no loss of quality (this is known as “smart rendering”). At any rate, this is the same quality as your camera which is why I suggested using it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeffrey Ellis
    December 18, 2009 at 10:47 am
    Ah. Ok, but I think I have a couple of fades in it — what would it be then?
  • John Rofrano
    December 18, 2009 at 11:11 am
    It would just render the fades and copy the rest. In the end, it’s always AVCHD.
    ~jr
  • Jeffrey Ellis
    December 18, 2009 at 7:39 pm
    Thanks, John 🙂
