Activity Forums Adobe After Effects Best Settings for 32 bit interlaced video output
  • Best Settings for 32 bit interlaced video output
    Posted by Mcqueen on September 8, 2007 at 1:16 pm
    Just starting on AE. It took me 4 years to get the hang of Ulead’s Cool 3D so I am trying to shortcut my AE learning curve.
    I work in PAL both full res. and compressed DV. I understand that the field dominance of full res. PAL is Upper Field First and that the field dominance of PAL DV is Lower Field First so I will have 2 different outputs for the 1 animation.
    I can live with this.
    In Cool 3D i prepared widescreen anims as 1024 x 576, standard 4:3 as 720 x 576 and saved them as 32 bit .avi files. I saved them as both Upper Field First and Lower Field First and they imported overlayed and played back on a TV monitor faultlessly.
    I have tried a couple of simple anims on AE but I can never get them to render as fieldsonly frames and they are a wee bit jittery on TV playback.
    Any ideas on which settings are best for me?
    Richard Harrington replied 19 years ago 2 Members · 4 Replies
  • Mcqueen
    September 11, 2007 at 8:22 pm
    Well? Can no-one help?
  • Richard Harrington
    September 12, 2007 at 12:14 am
    Not that hard…. just look at your render settings at output module
  • Mcqueen
    September 12, 2007 at 6:56 pm
    Still can’t determine how to set the field dominance for output on either 32 bit .avi or .mov files
    September 13, 2007 at 2:28 am
    Dude…. RTFM…
    I told you the answer… modify your render setting…
    Click its name and change its settings or go to your templates and modify…
    this is CLEARLY covered in the help menu
