Activity Forums Apple Final Cut Pro Legacy Best setting using Stills
  • Best setting using Stills
    Posted by Jimi Lund on November 17, 2008 at 6:29 pm
    I’ve got a bunch of hi-res jpegs that I want to add some motion to, accompanying some music.
    The final output will be a DV Pal DVD.
    So, a few questions:
    What’s the recommended sequence settings? Best compressor etc?
    Should I convert the stills to PNGs, or TIFFs first? I know jpeg’s not a good format.
    What’s the correct setting to accommodate the square-pixel-to-rectangular-pixel issue, if I correct the stills in FCP?
    Many thanks,
    Jimi Lund
    Jimi Lund replied 17 years, 9 months ago 2 Members · 2 Replies
  • Chris Poisson
    November 17, 2008 at 9:37 pm
    Jimi,
    Stills that are jpegs won’t get any better in quality by making them into tiffs. The damage is already done. But, as a rule, your stills should be twice the frame size at 72 dpi, too high rez images can choke FCP and cause artifacts.
    As to sequence settings, work in uncompressed 8 bit or ProRes, your final DVD will look better than if you work in DV. No need to work in square pixels.
    Have a wonderful day.
  • Jimi Lund
    November 19, 2008 at 10:28 am
    Cheers Chris
