Activity Forums Apple Final Cut Pro Legacy Best setting for titles?
  • Best setting for titles?
    Posted by Chris Long on June 21, 2011 at 10:07 pm
    Hi there,
    I’ve just completed a music video and need to add lower third titles. When I rendered them and watched them back, they looked awful – very ‘blocky’. Can anyone suggest a good workflow and format for titles? Should I create them in Motion 4 and export as animation, then import into FCP?
    Chris
    Chris Borjis replied 15 years, 2 months ago 3 Members · 4 Replies
  • Chris Borjis
    June 21, 2011 at 10:15 pm
    Chris are you using the included Boris 3d Titler?
  • Chris Tompkins
    June 21, 2011 at 10:48 pm
    Your sequence settings?
    Chris Tompkins
    Video Atlanta LLC
  • Chris Long
    June 21, 2011 at 11:11 pm
    No, I’m just using the regular text tool from the drop down. Your question as to the sequence settings is a good one – I’m using someone else’s Macbook Pro and I need to check the settings since I took over the edit – thanks for reminding me!
  • Chris Borjis
    June 24, 2011 at 4:47 pm
    use the boris 3d titler….the apple one is awful.
