Activity › Forums › Apple Final Cut Pro Legacy › best set up for burning multiple DVD’s ?
Posted by Bill Willins on June 6, 2005 at 10:11 pmRight now I’m authoring my DVD projects in DVDStudio Pro , then burning the discs one at a time on my dual G5 internal DVD burner. This process is too slow and inefficient. If I need a large quantity I send them out …. but so often I just need about 15 or 20 DVD’s ….. so what’s my best solution to streamline this process. thanks 🙂
Juli Brown replied 21 years, 3 months ago 11 Members · 11 Replies -
Jerry Hofmann
June 6, 2005 at 10:43 pmThis: https://www.meritline.com/index.html Sells a whole slew of brands etc. I’d be looking for a dual layer duplicator for those big HD dups of the future…
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Matt Murray
June 6, 2005 at 11:23 pmJust “build” in DVDSP, then use Toast Titanium to burn them.
You can choose the amount and burn speed, set it for the amount, and just feed it disks.
With the new software and computer setup I have, it’s now about 8-11 minutes each for DVD’s to burn.
Matt Murray
Lineside Productions
Wellington, FL
https://www.edgesportfishing.com
Florida Sailfish videos, pictures and more
My World Video ProductionsMac OS X 10.4.1 , QT 7.0 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD 5, DVDSP 4, Compressor 2.0, Motion 2.0
Soundtrack Pro 1 -
Thaxter Clavemarlton
June 7, 2005 at 12:26 am[Matt Murray] ” 8-11 minutes each for DVD’s to burn.”
How long is the original program material for an 8-11 copy?
Jeff Carpenter
June 7, 2005 at 3:20 amI’ve got one of these and I love it:
https://www.primera.com/bravoII_disc_publisher.html
It comes down to how much you’d use it to know if it’s worth the price to you. The BEST thing about it is that it prints on the labels. When I have to make 100 copies the printing is a bigger time saver than the burning itself. I didn’t even get the extra tray attachment, so I can only do 25 in one batch, and that’s still fine for me. It can do about that many overnight. It could go even faster but I like to burn at less-than-the-fastest speed just to be safe.
The suggested reatil price on that page is much higher than they actually sell for. You can find them for about $1,800 if you look around the ‘net.
You may not need something like this, but it’s worth considering.
Mitchji
June 7, 2005 at 6:49 amHi,
A stand alone one to three or one to five tower is one way to go. You can purchase the parts and assemble yourself if you want to save a few hundred.
Best Wishes,
Mitch
Walter Biscardi
June 7, 2005 at 11:39 amthey have several units which do multiple DVD’s and even do the printing right on the discs.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Godfrey Pye
June 7, 2005 at 2:25 pmI want to throw in my vote for the Primera Bravo 2. I have one and it’s like the Energizer bunny – it goes and goes producing and labeling DVD’s. There’s a thrill when you wake up in the morning and find that you have a bunch of completed, labeled discs ready for you, all made while you were sleeping.
I have mine connected to a Mac Mini, connected to my network.
I can’t remember having a dud disc as yet.Godfrey Pye
Mulholland Bays – in the Hollywood Hills -
Bill Willins
June 7, 2005 at 3:20 pm“I have mine connected to a Mac Mini, connected to my network. “……. This set up sounds great. So help me here ….. You can author your DVD and work in DVDSP on the G5 … and then send the project through the MacMini without tying up the G5 ? And wile the DVD’s are burning you can continue to work on the G5 ?
Godfrey Pye
June 7, 2005 at 3:50 pmI have mine connected to a Mac Mini, connected to my network. “……. This set up sounds great. So help me here ….. You can author your DVD and work in DVDSP on the G5 … and then send the project through the MacMini without tying up the G5 ? And wile the DVD’s are burning you can continue to work on the G5 ?
Yep – that’s exactly right. Via the software that comes with the Bravo 2, I make an disk image of the completed DVD project, using iDVD or DVDSP – that goes onto my RAID along with the label which I author (on either computer) in Discus then make a bmp file of that which I size in Photoshop.
Then the Bravo 2 selects both the Photoshop file and the disk image, then one-by-one the robot arm of the Bravo 2 takes a disk from the right hand hopper of 25 blank disks, writes the program on the disk, writes the label on the same disk and drops it into the left hand hopper – then it moves on to the next disk. I choose quality and not speed (for obvious reasons) and – touch wood – I haven’t had one disk failure yet.
Meanwhile, I carry on working in FCP or whatever, on the G5, safe in the knowledge that my mini factory is slowly churning out DVD’s,completely unattended.
Godfrey Pye
Gabriel Regalbuto
June 8, 2005 at 7:00 pmWe slapped a stack of four burners in a Windows PC. Using Nero, you can burn to them all at once. Just transfer the image folder over or burn one on the Mac and copy in Nero.
