Activity Forums Adobe Premiere Pro Best sequence settings for editing H.264
  • Best sequence settings for editing H.264
    Posted by Anthony Vamvakitis on September 23, 2015 at 5:36 pm
    Using Premiere Pro to edit h.264 5D footage. It was my understanding that Premiere Pro can edit it natively, and it can (well, sort of), but it is definitely sticky going through the timeline and as the sequence grows to 3 minutes, is getting more unstable.
    Any suggestions to get smoother jogging through clips and sequences? I’m using an eSata connection and have done Alexa footage on it before without issue so I don’t think it’s my system.
    Anthony Vamvakitis
    http://www.editor-at-large.net
    Shane Ross replied 10 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Warren Eig
    September 23, 2015 at 6:41 pm
    On a Mac, convert to ProRes. You’ll also avoid constant recompression and bending in effects you apply.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Anthony Vamvakitis
    September 23, 2015 at 6:48 pm
    Thanks, Warren. Unfortunately on this project there’s too much footage and not enough time.
    Anthony Vamvakitis
  • Andrew Kimery
    September 23, 2015 at 6:59 pm
    You can edit natively but working with h.264 is more taxing than on the CPU than, say, ProRes. If transcoding isn’t an option then trying reducing the playback quality to 1/2. Also make use all the cache files (which PPro accesses a lot) are on a fast drive too.
    September 23, 2015 at 7:25 pm
    Thanks, Andrew. The note about the cache was useful. They were on my boot disk so I switched them to the G-raid with eSata connection. Hoping that helps.
    Anthony Vamvakitis
    September 23, 2015 at 7:36 pm
    By the way, any suggestions on timeline settings, or does that not matter. Doesn’t seem to but thought I’d ask. I’m coming from FCP where that really mattered.
    Anthony Vamvakitis
  • Andrew Kimery
    September 23, 2015 at 7:46 pm
    [Anthony Vamvakitis] “By the way, any suggestions on timeline settings, or does that not matter. Doesn’t seem to but thought I’d ask. I’m coming from FCP where that really mattered.”
    Timeline setting, as least as far picking a codec goes, only impacts your preview files (what FCP called render files). For example, if you choose DNxHD as your timeline codec then when you render an effect the render file will be in DNxHD.
  • Shane Ross
    September 23, 2015 at 8:41 pm
    Timeline settings aren’t the issue, and won’t affect playback. It’s the source footage that’s causing the slowdown. Solutions for that are more RAM, GPU that enables the Mercury engine and fast processors. Adobe solves the “working native” by throwing resources at it…RAM, Processors, GPU.
    Shane
    Little Frog Post
