Activity › Forums › AJA Video Systems › Best Seq. Settings for offline 23.98 DVCPROHD w/ LHe
  • Best Seq. Settings for offline 23.98 DVCPROHD w/ LHe
    Posted by Schmattakid on May 7, 2007 at 11:42 pm
    Our source is HDCAM 23.98, and we’d like be be doing an offline edit using the DVCPROHD codec at 23.98.
    Is there a painless way that runs nativly and won’t require huge renders?
    We’ve run into some surprises in our on-line sessions from not working in the same resolution.
    Thank you!
    Walter Biscardi replied 19 years, 4 months ago 2 Members · 1 Reply
  • Walter Biscardi
    May 8, 2007 at 12:27 am
    [schmattakid] “Our source is HDCAM 23.98, and we’d like be be doing an offline edit using the DVCPROHD codec at 23.98.
    Is there a painless way that runs nativly and won’t require huge renders?”
    You mean editing natively? Just set up the DVCPro HD 23.98 Easy Setup and capture from your HDCAM source and you’re good to edit. No rendering required, it’s all realtime.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
