Activity Forums Adobe After Effects Best SD comp size
  • Best SD comp size
    Posted by Billie O. on August 3, 2005 at 1:51 am
    I am a promotions producer for a television station. I have always built my D1/NTSC comps 720×486. When I create still artwork I do use 720×540 and scale to fit once inside the AE comp. However I was just told that it is better to do the entire project, including comps 720×540 square pixels and then render to 720×486. I dont much like the idea of scaling my video 10% but was told that its a wash when rendered back down. Is there any validity to this? Looking for pros and cons.
    Billie O.
    Joeythedog replied 21 years, 1 month ago 3 Members · 2 Replies
  • Steve Roberts
    August 3, 2005 at 2:54 am
    Now there’s a debate. Many prefer to work in 648×486 square pixels, claiming greater fidelity to the original when dropped into a D1 comp. Others believe that would be enlarging the image, so they prefer to reduce from 540 to D1. Me, I work in D1 using pixel aspect ratio correction, but switch it off when rendering or when checking the TV output from the Decklink card.
    (I rarely bring in full-frame stills)
    Look for Rick Gerard’s article, Dr. Strangepixel on the COW — hope it helps.
    Steve
  • Joeythedog
    August 3, 2005 at 6:04 am
    After several hours of reading and study. I feel that creating photos and graphics formats in photoshop at 720 x 540 will be my approach. Working composition size NTSC D1 720×540 square pixels. Render format NTSC D1 720×468- which produces a rectangle pixel for viewing on a television set.
    This seems the proper way to go about things.
