Activity › Forums › Apple Final Cut Pro Legacy › Best route for HDV/DVCProHD to ProRes
  • Best route for HDV/DVCProHD to ProRes
    Posted by Liz Smith on April 8, 2008 at 9:55 pm
    Hi folks,
    I need some purchasing advice…
    My Gear So Far:
    New Mac Pro (8-core), the latest FCP, and a Panasonic AJ-1400
    Need to get:
    HDV Deck
    Capture card?
    What: I’d like to capture HDV and DVCPro footage from decks straight to ProRes – efficiency and quality outweighing cost, within reason.
    My big question:
    I can do this all via firewire (right?), but is there any reason to do this instead via an HD-SDI capture card? I’m looking for the smoothest route – with batch capture and no transcoding after capture, etc. I don’t want to work in native HDV and then render to another timeline. I’d like to deal in one format/codec once the footage is captured. (And I won’t be mastering to HDV at all, but probably will output to the AJ-1400.)
    I’m looking for suggestions on which HDV deck/converter/capture card combo to set-up with.
    Liz
    Erik Naso replied 18 years, 5 months ago 4 Members · 15 Replies
  • 15 Replies
  • Walter Biscardi
    April 8, 2008 at 10:43 pm
    We convert HDV to DVCPro HD all the time via the AJA Kona series. ProRes has been unimpressive to me vs. DVCPro HD which we’ve been using for three years now. DVCPro HD is a proven, very clean codec.
    But back to your question, the AJA Kona series makes it very easy to convert your footage from just about anything to just about anything. The Kona 3 also allows us to go 720 to 1080 or 1080 to 720 which is huge in our workflow.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Liz Smith
    April 8, 2008 at 10:58 pm
    Thanks Walter…
    It’s looking more and more like a Kona card is the truly smooth solution. All of the posts and articles I’ve read so far seem to suggest that importing HDV via firewire and getting to another format for editing is kind of a nightmare. (And by nightmare, I mean all of the transcoding, rendering, and re-naming? clips… and capturing entire tapes at once? That’s madness.)
    I’m a fair-weather editor. I want to log-and-capture individual clips and edit immediately.
  • Walter Biscardi
    April 8, 2008 at 11:04 pm
    [Liz Smith] “I’m a fair-weather editor. I want to log-and-capture individual clips and edit immediately.”
    Then the Kona is what you want. Simply select the Easy Setup for what you want and start digitizing.
    Need multiple outputs from your timeline? Simply let the Kona Upconvert or Downconvert from a single timeline.
    It’s really a plug and play device. Just be sure to read up on how the Control Panel operates. It can operate independent of FCP and that’s how you get all the realtime Up, Down and Cross Conversions.
    Read my Blog!
  • Liz Smith
    April 8, 2008 at 11:26 pm
    Great! But… the Aja site is telling me that Kona LHe is not compatible with Leopard yet? What’s up with that?
    For HDV, do you use the HD-SDI or analog composite in from the deck? It seems weird to go digital-analog-digital, but it would be cheaper in terms of HDV decks. A lot cheaper.
  • Walter Biscardi
    April 8, 2008 at 11:29 pm
    [Liz Smith] “For HDV, do you use the HD-SDI or analog composite in from the deck? It seems weird to go digital-analog-digital, but it would be cheaper in terms of HDV decks. A lot cheaper.”
    Analog Component from a Sony M15U to an AJA HDAVA10 Converter. Converts Component and audio to HD-SDI with embedded audio. We have two of these units.
    As far as Leopard compatibility, the drivers have been available for at least a few months now.
    https://www.aja.com/html/support_konaLHe_swd.html
    Read my Blog!
  • Liz Smith
    April 8, 2008 at 11:47 pm
    oops – I meant component. And right on about Aja/Leopard! It stills says on one page that they are working on it.
    Alright! One last question – at least until I get the darn things and have to make them work…
    I saw the AJA HDAVA10 – pretty nifty. Is there any reason (besides the LCD screen) to get the M25U?
    Or – someone else mentioned getting the GV-HD700… it’s got HDMI as well, a big screen, and I could use it’s portability. It only plays back HDV w/o recording, but I have a hard time imagining what I would need that for anyway. It appears to have all the I/Os that I would need, including firewire. Any reason you didn’t go with this one?
    (OK, that was two questions.)
  • Liz Smith
    April 8, 2008 at 11:50 pm
    OK, third question:
    Michael Palmer over on the HDV forum just noted: “I use the M25 deck together with a Convergent Design MI (HDMI-HD-SDI converter) into my Kona LHe card and it works great keeping the original timecode during the transcode.”
    Are you able to keep the timecodes for re-capture going the component/M15U route?
    Liz
  • Chris Borjis
    April 8, 2008 at 11:52 pm
    I would stick with the deck for sure.
    Those portable players are nice, but don’t quite have the robust build quality of a pro deck.
  • Walter Biscardi
    April 8, 2008 at 11:55 pm
    [Liz Smith] ”
    Are you able to keep the timecodes for re-capture going the component/M15U route?”
    Timecode just comes in as part of machine control on Firewire.
    Read my Blog!
  • Liz Smith
    April 9, 2008 at 12:04 am
    Yeah, the portable player is a nice idea. But I wasn’t sure about it.
    Is there any reason to get the M25U? I read that some folks really appreciated the on-board LCD screen b/c of lag time on the computer window viewer – but perhaps that was just a problem with firewire capture.
