Activity Forums VEGAS Pro Best rez for stills?
  • Best rez for stills?
    Posted by John Magee on December 7, 2007 at 1:44 am
    I’m importing jpegs for a slide-show. They are large – I forget the exact rez.
    Is there an ideal size that I should convert these to (in photoshop), and if so, does it affect much besides render-times? I don’t want to do all that work unless it will have a significant effect on the look of the DVD.
    Dave Petteruto replied 18 years, 9 months ago 5 Members · 4 Replies
  • Neil Moxham
    December 7, 2007 at 3:30 am
    I have found that a 2 to 1 or 1to1 ratio to the video is good.
    If you are not pushing (zooming) into the still then this formula works.
    -resize the still in photoshop with the “image/ resize” tool.
    -make sure the “lock aspect ratio” is checked.
    -set the amount of horizontal 720, the other will self adjust into place.
    Save as PSD or jpg
    Try 1440 if you have thin lines. it helps those edges a little.
    Too high of a rez and those pics will jump around on you.
    Good luck
    Zipedit
  • Douglas Spotted eagle
    December 7, 2007 at 3:45 am
    We use a script that takes the greater of the horizontal/vertical values and reduces it to 2K. Of course, this assures that the other value is also reduced to a more optimal number.
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Rick Mac
    December 7, 2007 at 3:54 am
    Assuming that you are in the US (NTSC Video) and that your
    project is SD not HD, and you are resizing stills outside of Vegas, such as with Photoshop, here is the recommended size.
    If you are not zooming in with Pan/Crop: 655X480
    If you will be zooming in tighter with Pan/Crop 1310X960
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
  • Dave Petteruto
    December 7, 2007 at 2:18 pm
    Douglas, where can one get a copy of that script? Is it an action that has been created in Photoshop?
    Dave P.
