Activity Forums Apple Final Cut Pro Legacy best resolution for still images in Final Cut Pro
  • best resolution for still images in Final Cut Pro
    Posted by Lee Frank on April 12, 2011 at 1:29 pm
    Hi all,
    I just have to gush thanks for all the great tips and tutorials authors put up on this site. I work in a far flung part of northern Australia and this kind of resource is absolutely critical for me to get the results I need.
    I’ve been scouring CreativeCOW, Larry Jordan’s online webinars and the net more generally for about a week trying to figure out why I can’t see my photos in full screen final cut with the same clarity I can view them in Photoshop or Aperture.
    I’ve tried adjusting my video settings in FCP, I’ve tried resizing my stills in Photoshop, I’ve tried directly dropping 3 mb shots into my FCP browser but nothing seems to do the trick.
    I’m creating a short film using still images and video. The real pain is when I zoom in to the stills the resolution is shot to hell.
    My sequence preset is Dv PAL 48 kHz Anamorphic
    Capture preset as above
    Frame size 720 x 576
    editing time base 35 fps
    Pixel aspect ratio PAL CCIR 601
    Anamorphic 16:9 On
    The photos range from 2048 x 1536 72 dpi to 3256 x 2440 72 dpi
    I suspect my photos are being automatically resized to fit the 720 x 576 frame size.
    I’ve hesitated to write a post as it seems this issue is quite common one but after exhausting all other avenues I humbly request assistance here.
    Many thanks for your patience and tolerance
    Lee Frank replied 15 years, 5 months ago 4 Members · 6 Replies
  • John Knapich
    April 12, 2011 at 3:35 pm
    It looks to me like your photos are fine, the right size to move and zoom in FCP. Have you tried rendering out a full rez quicktime from FCP to see what the final result is? Sometimes FCP does not do photos justice in the viewer depending on your settings.
    BTW, when I have a project with lots of photos, I sometimes end up doing the moves in After Effects. Adjustments and rendering seem faster there to me.
    FCP 6.06, OS 10.5.8 2x3GHZ Quad-Core Intel Xeon, Kona LHe, Dulce Duo-eSATA 8 Drive, 4TB Raid.
    John Knapich
    Creative Director/Partner
    Assembypix.tv
  • Mark Suszko
    April 12, 2011 at 4:44 pm
    You are in the DV codec. Maybe you’re asking too much of it.
  • Paul Jay
    April 12, 2011 at 10:29 pm
    Use a ProRes 422/444 HD or 2K timeline.
    DVPAL compression is terrible.
    And you are in a SD timeline.
    Why?
  • Lee Frank
    April 13, 2011 at 11:15 am
    Thanks John,
    Yes, have rendered a full res quicktime and the shots appeared much the same as they did in the canvas. I’ll keep on trying with FCP as it’s the app I know. Until such time as the wall upon which I’m bashing my head triumphs I’d prefer to stay with FCP – bloody skull n all.
    [John Knapich] “Sometimes FCP does not do photos justice in the viewer depending on your settings. “
    Can you tell me what settings these are?
  • Lee Frank
    April 13, 2011 at 11:27 pm
    Hi Paul, Thanks for your comments. I have started a new project with the settings you outlined but am still having trouble getting the fine detail I can so readily get with Photoshop. The settings I posted originally were given to me as the best for the short film festival I’m entering.
    I’m using PAL since I’m based in Australia. When I make it home I’ll post my current proRes settings and a cropped image comparing the original shot to the image shown in FCP.
    I’m also trawling through old posts on Creative Cow and seeing what can help.
  • Lee Frank
    April 16, 2011 at 11:23 pm
    Thanks everybody I tweaked the settings and viola! with Sequence preset at Apple ProRes 4444 1920 x 1080 25 p and capture preset at DVCPRO HD 1080i50 things are looking decidedly up.
