Activity › Forums › VEGAS Pro › Best Rendering Setting & Export To DVD Arch
  • Best Rendering Setting & Export To DVD Arch
    Posted by Sean Windsor on February 3, 2009 at 10:45 pm
    Hi Guys,
    I am rendering in high definition from a Sony HVR-Z1 and burning onto a single layer dvd. Whats the best settings to render in vegas for HD and for it to export to DVD architect 5?
    Also can I set the chapter markers in vegas so I dont need to them in Arch.
    Any help would be appreciated,
    Thanks guys.
    Sean.
    Enrique Orozco replied 17 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    February 3, 2009 at 10:54 pm
    If you are trying to make a standard definition DVD render the video using the MainConcept MPEG-2 file type with the DVD Architect NTSC Widescreen video stream template (or PAL). Then render the audio using the Dolby Digital AC-3 file type with the appropriate template for your project (stereo or 5.1)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sean Windsor
    February 3, 2009 at 11:15 pm
    Hi John,
    Thanks for your quick reply. Would the quality be better if I am rendering in MainConcept MPEG-2 but with HDV 1080-50i?
    Also in the video tab of the template should I always move the scale to the highest for video quality?
    Thanks again in advance.
    Sean.
  • John Rofrano
    February 4, 2009 at 12:20 am
    It depends on what type of disc you are creating. You cannot place HD media on a standard definition DVD.
    Are you making a DVD to play on set-top DVD players or are you trying to create a hybrid Blu-ray Disc on plain red-laser DVD media to be played in a Blu-ray player or PS3?
    The answer to that question will determining what you can place on the disc.
    ~jr
  • Sean Windsor
    February 4, 2009 at 12:37 am
    Its a standard burn, but what I normally do is render it in HD because its been recorded in HD and use DVD arch to burn it which compresses it to standard disc.
    Ive found I get better quality when its rendered in HD as opposed to PAL Standard.
  • John Rofrano
    February 4, 2009 at 1:20 am
    DVD Architect is recompressing the file to PAL MPEG-2 anyway. You might as well render to PAL MPEG-2 in the first place and avoid the extra render to HD which can only loose quality from what’s on the timeline.
    ~jr
  • Sean Windsor
    February 4, 2009 at 6:00 am
    Thanks John,
    that was helpful, appreciate it.
    Sean
  • Enrique Orozco
    February 4, 2009 at 2:12 pm
    For producing SD-DVDs from HD recordings I found very comfortable working in SD timelines (let me pan & crop) and rendering (as John says) to mpeg2 DVD arch widescreen template… be sure to render with BEST settings (not big difference with SD recordings)…
    good luck
    Enrique Orozco R.
    iDEA DigitalVideoStudio
