Activity Forums VEGAS Pro best render vegas 10 pro for youtube
  • best render vegas 10 pro for youtube
    Posted by Jerry Rio on January 9, 2011 at 7:54 pm
    I”ve seen dozens of tutorials on youtube, read some threads and have gotten answers from some very helpful forum members.
    I have a few questions.
    Are some of the tutorials about rendering in HD or even HQ widescreen talking about video shot on a digital or HD camera that puts out a bigger aspect ratio. Therefore when I use their settings for a template I don’t get such great results.
    The video I am rendering came from an S-VHS camera and was digitized using a canopus 110 into DV AVI files in sony vegas.
    I was advised that I render a loss less AVI file and use another program to convert that to h264 for uploading to youtube
    I would prefer not to add the other step and just render directly from Vegas to upload to youtube. I also tried the xvidps4p converter (or something like that) and there were so many settings. And I couldn’t follow the tutorial on Youtube for using that.
    I thought I read somewhere that vegas 10 can output directly to the 264…..is it X or H codec, but I don’t see where.
    Can you import it the codec……… or if you are willing to upload a fairly large video file there is no need to compress the file anyway and not use 264 at all.
    Also is my video meant to be widescreen, will I lose quality if I am changing the aspect ratio. Would it be better to not have widescreen and have the black borders…I don’t mind, but If I can get fullscreen with no loss of quality, I could go for that.
    Most tutorials advise creating a template using various rates and frame sizes and aspect ratios, most render to WMV files, on version 10 that would be WMV11.
    I have tried some of those settings with varying results. Not much better than some of my earlier Mpg4 rendered in SonyMain Concepts MPG4 which I know could look better.
    I would greatly appropriate it if anyone can answer some of these questions and/or give me a link to a tutorial that would suit my needs or a thread that has the best settings in Sony Vegas for getting the best quality from the video source that I am using.
    I know I didn’t start with high quality video but I just want to maintain as much of the current quality as I can and also in a format that looks good on youtube as that is my main outlet for the video at this time.
    Thanks much!
    John Rofrano replied 15 years, 7 months ago 3 Members · 6 Replies
  • John Rofrano
    January 9, 2011 at 10:05 pm
    [Jerry Rio] “I thought I read somewhere that vegas 10 can output directly to the 264…..is it X or H codec, but I don’t see where. “
    Use the Sony AVC render type with the Internet 640×480-30p template for old SD recordings.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Aleksey Tarasov
    January 9, 2011 at 10:07 pm
    For a start, you can use free plug-in, Video4YouTube. Read the manual for best results.
    Best regards.
  • Jerry Rio
    January 12, 2011 at 7:01 pm
    Hi John, I appriciate you taking the time to help me. Your suggestion rendered a decent looking image and a pretty small file. But I have a friend who rendered the same video (from S VHS) as mine in a HD format that looked much crisper and sharper. I don’t mind dealing with a larger file. I know a lot of people recommend WMV11.
    So is there another setting or template or tutorial that will show me how to get better results. As I stated before, I didn’t start with HD video or even digital video, but the S VHS I made into AVI files to edit in vegas look pretty good and I’m sure I can get a render setting that will give me better results on youtube.
    Thanks a lot!
  • John Rofrano
    January 12, 2011 at 9:00 pm
    [Jerry Rio] “So is there another setting or template or tutorial that will show me how to get better results. “
    You can increase the bit-rate in that template or use one of the Internet HD templates. The higher the bit-rate the higher the quality.
    ~jr
  • Jerry Rio
    January 12, 2011 at 9:55 pm
    Thanks John,
    Yeah, I looked at the video again. It really didn’t look bad. So try increasing the bit rate…by how much?
    Also can I use the audio in the MPG4 file or should I render the audio separately like youtube says to in an mp3,
    I’ve read there are better formats than mp3, so which should I use.
    or should I not render a separate audio file. I know how youtube can grab the audio file with the video if it has the same name and timing.
    And if I use the audio in the Mpg4 should i set to 4800 instead of 4100
    or will that not make a difference.
    Thanks a lot
  • John Rofrano
    January 12, 2011 at 10:49 pm
    [Jerry Rio] “So try increasing the bit rate…by how much?”
    I would increase it in increments of 500,000 Kbps until you can’t tell the difference or reached your desired file size.
    [Jerry Rio] “Also can I use the audio in the MPG4 file or should I render the audio separately like youtube says to in an mp3, “
    Use the audio in the AVC file. It’s AAC audio and will sound great.
    [Jerry Rio] “And if I use the audio in the Mpg4 should i set to 4800 instead of 4100 or will that not make a difference. “
    I always use 48,000 for all of my audio as this is what most video cameras use so chances are the original audio is 48K. That’s what I suggest you use.
    ~jr
