Activity Forums Apple Final Cut Pro Legacy Best render settings
  • Best render settings
    Posted by Andy Hutchinson on May 30, 2005 at 11:17 pm
    I have read and read but I can’t find the answer to this. What is the best way to render to get the best output. I thought doing the Option/R would give me the best quality but it seems I have to also check the “Full”. I record to my DSR20 from the timeline so that is why I need to know. After doing the Option/R I was seeing some very light grey on the top of the timeline. I couldn’t see any difference in playing it when a previous part of the clip was dark grey or light grey. If I place the pointer over the light gray it says Full and the dark gray area says Media. The Full is in a cross dissolve transition.
    Is there one keystroke that will render everything 100%?
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
    OS-10.3.7, FCP4.5, SP 2.05, Dual 2.5 G5, 2 gigs RAM; Sys HD 200G : WD 200G 7200rpm with 8 Meg buffer; 2 WD 250G 7200 rpm with 8 Meg buffer FW enclosure; Lacie FW800 card; Maxtor 120G FW for storage, 1 WD,
    Pdr replied 21 years, 3 months ago 3 Members · 2 Replies
  • Bret Williams
    May 31, 2005 at 3:36 am
    Full means that it has the capability to playback in RT at full quality. Checking to render stuff that is tagged as FULL means that it will render it, even though your system, card, etc. can play it back at full quality in RT.
    Doesn’t mean it won’t skip a beat and drop a frame. I check every render box and if I hit option+r I want everything rendered. No guessing. I hate those silly check items almost as much as the problems that fill this forum because they default to being unchecked.
  • Pdr
    May 31, 2005 at 7:17 am
    Hey Andy
    If you have everything activated on your Sequence > Render All menu, then opt-R should render at best quality.
    This in an awesome article; it really helps one get their head around RTExtreme and rendering.
    https://www.kenstone.net/fcp_homepage/rendering_rt_fcp_4_balis.html
    Hope this helps.
    Regards
    Peter
    Peter Dominic Ryan – Freelance Editor
    raycity* media – pdr@raycity.com
    PowerMac G5 Dual 2.0 GHz, 4GB, Mac OS X 10.4.1
    PowerBook G4 17″ 1.67 GHz, 2GB, Mac OS X 10.4.1
    FCPro 5, Soundtrack Pro, Motion 2, DVD SP 4
