Activity Forums DVD Authoring best red 2k down to Blu_ray
  • best red 2k down to Blu_ray
    Posted by Ross Byron boughton on January 21, 2010 at 4:43 pm
    hi guys have been using share to compressor to burn blu-Ray disks
    i have toast 10 and am thinking about downsizing the footage to 1080i first
    (which codec and frame rate is best can i stay in 23.97?)
    then going to toast
    as sometimes burning though compressor is unstable and you can not do a reburn after a few days if the client wants more
    any thoughts would be great
    tia
    Ross byron
    Ross Byron Boughton
    Editor / Webmaster / Sound Designer 917-538-0823_
    E-mail:rbellevue@aol.com https://www.inch.com/~bellevue/
    Ross Byron Boughton
    Eric Pautsch replied 16 years, 7 months ago 2 Members · 6 Replies
  • Ross Byron boughton
    January 21, 2010 at 8:18 pm
    PS i have the adobe media encoder 4 which really seems to fly
    Ross Byron Boughton
  • Eric Pautsch
    January 22, 2010 at 5:20 am
    You need to encode a 1920×1080 10bit Uncompressed file @ 23.98. Personally, I’d pay someone with a professional encoder and a little BD know how to do this work. Why shoot with a RED, then use prosumer tools to output a product the client will ultimately see? I can never understand this. Would you hire someone who has no RED experience to shoot?
    January 23, 2010 at 2:01 pm
    thanks thats what i thought it might be
    what other compression programs or hardware would you be referring to
    best
    Ross B
    Ross Byron Boughton
    January 23, 2010 at 8:12 pm
    have had great results with making my SD versions that way as well
    i resize and center crop it down to a 720 486 10bit uncompressed then make an mpeg2 out of it
    in compressor i use the inspector tab to amp up my setting to best motion and resize 2pass ect.
    will do a test and post latter
    Ross Byron Boughton
    January 28, 2010 at 10:13 pm
    burned on in toast no sound from 1080 24pm 10bit uncompressed
    will revist my work flow maybe try a 720 pm
    am using duel layer disks gotta say with out the sound the picture was great! on my 40inch tv
    Ross Byron Boughton
  • Eric Pautsch
    January 29, 2010 at 7:10 pm
    You should see your footage on a good encoder and see what you’d say! 🙂
