Activity Forums Creative Community Conversations Best RAID drive for RAW Cimena DNG
  • Best RAID drive for RAW Cimena DNG
    Posted by David Mathis on June 29, 2014 at 6:18 pm
    I currently own a Blackmagic Cinema Camera and looking for a reasonably priced storage solution. I mainly shoot in the RAW format. Considering a RAID drive, looking for advice on enclosure and drives. I have the old school Mac Pro so thunderbolt connection is not an option at this time. Is it possible to go with Ethernet or would another connection be a better option? Any advice is greatly appreciated.
    Core Software:
    FCP X 10.1.2
    Motion 5.1.1
    Resolve 11
    Compressor 4.1.2
    OS X 10.9.3 Mavericks
    Mitch Ives replied 12 years, 2 months ago 8 Members · 16 Replies
  • 16 Replies
  • Shane Ross
    June 29, 2014 at 7:37 pm
    ESATA won’t cut it. Not even sure GIGe Ethernet is fast enough. Fibre might be. CalDigit HDOne or similar. But that’s a lot of money to throw at old tech.
    Shane
    Little Frog Post
  • John Davidson
    June 29, 2014 at 7:55 pm
    Hey David, I have an extra ATTO R680 and a 24 TB 8 drive ProAvio RAID we no longer use just collecting dust. The RAID gets about 400-500 Mbps read/write speeds if I remember correctly. I’d be happy to discuss sending it to you to try out if you’d like.
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Mitch Ives
    June 29, 2014 at 8:20 pm
    Promise Pegasus 2… with TB2… 800-900 in throughput…
    Mitch Ives
    Insight Productions Corp.
    “Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things.” – Winston Churchill
  • Shane Ross
    June 29, 2014 at 8:46 pm
    Mitch, he said Thunderbolt WAS NOT an option.
    Shane
    Little Frog Post
  • David Mathis
    June 29, 2014 at 8:51 pm
    Thunderbolt to Ethernet adapter possible? Thanks for the input everyone.
  • David Roth weiss
    June 29, 2014 at 10:23 pm
    If it were possible, you would be getting approximately 90MB/sec max over Ethernet from a RAID array capable of 1000MB/sec. Probably not your best use of resources.
    A SAS connected 8-drive RAID such as the one John has offered you is your best bet.
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Bob Zelin
    June 29, 2014 at 11:06 pm
    your real question is “what is the cheapest way I can do this”.
    John Davidson’s offer is the best offer you are going to get, if price is the main consideration. You need a REAL RAID array, with a REAL disk drive host adaptor (cost over $900 for the card), and a minimum of 8 disk drives. I don’t care what brand you get – those are your specs for your Mac Pro to accomplish what you want.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Oliver Peters
    June 30, 2014 at 1:54 am
    Are planning to edit directly with the raw DNG files? Generally that’s not recommended. Also X doesn’t interpret the raw information. It just imports the clips with baked info – sometimes with incorrect levels. Have you looked into using Resolve in a workflow to render the clips into MOVs?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • David Mathis
    June 30, 2014 at 2:00 am
    I plan to render out proxies from Resolve first, edit in FCP X then back to Resolve first. Will apply a LUT as well. Going to use the workflow as Denver Riddle uses.
    I am an avid user of FCP X!
  • Chris Kenny
    June 30, 2014 at 5:14 am
    [David Mathis] “I currently own a Blackmagic Cinema Camera and looking for a reasonably priced storage solution. I mainly shoot in the RAW format. Considering a RAID drive, looking for advice on enclosure and drives. I have the old school Mac Pro so thunderbolt connection is not an option at this time. Is it possible to go with Ethernet or would another connection be a better option? Any advice is greatly appreciated.”
    This is the 2.5K camera? I don’t know why you’re getting all these responses about needing 8+ drives. This isn’t uncompressed 16-bit 4K DPX or something, it’s 2.5K raw. It’s only about 120 MB/s — a single 7200 RPM drive will do that, though not solidly enough to rely on. Your cheapest option on an old Mac Pro would be to get a USB 3 or eSATA card, a dual drive enclosure, and a couple of 7200 RPM drives, and run the thing RAID 0 (this would work, by the numbers, though I haven’t used that particular model). Of course, you’d want to keep really good backups of footage and probably store project files, etc. somewhere else with RAID 0, since you’d lose everything if either drive died.
    You could also just use Disk Utility to set up software RAID 0 across two or three internal drives, if all your footage will fit into that sort of storage space.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
