Activity Forums Adobe Premiere Pro Best quick time settings for broadcast
  • Best quick time settings for broadcast
    Posted by Yerb Khan on September 29, 2010 at 2:52 am
    Hello,
    Probably there is a thread in this or other forums that explains my question but I was searching the internet for some time now and I can’t find a suitable answer. I am a PC user so MAC guys out there please don’t laugh 🙂 I am using a Premiere CS4 and I have a big problem adjusting the video output settings for final “broadcast quality” delivery.
    What wrapper/codec should I use in order to achieve maximum quality output. When I export video from AE I get perfect result using Quick time Photo JPEG output but if I choose the same setting in Premiere the video is very bad quality. And so far everything that I have tried only delivers very poor quality. No matter what I choose I can’t get anything near to that of AE output. What is the problem here.
    Thanx
    Yerb Khan replied 15 years, 6 months ago 3 Members · 5 Replies
  • Kevin Monahan
    September 29, 2010 at 4:39 pm
    What is your deliverable? Tape? If so, what kind of tape? DVD? A file for online playback? Let’s start with what you will need to deliver, then you can determine your output.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Yerb Khan
    September 29, 2010 at 5:30 pm
    My client puts this into Final Cut and transfers it to a BETA tape before it is sent to a TV station. Video format is 1024×576 which is also my premiere project where I add intro and outro to my content. I also tried “Animation” compressor which my client reccomends and from AE it is perfect. But the same setting isn’t working in premiere.
    My workaround so far is that I put intro and outro into my AE project and and export the wohole thing. But I would like to know why is Premiere output not working or why is it different then AE output with same settings. In case I have to edit a longer video I will eventually need Premiere in order to deliver high quality output.
    Thanx,
    Yerb
  • Pascal Movsessian
    February 14, 2011 at 5:51 pm
    hi i have a sony z1 and i have pc windows pentiom 4 core 2 duo 4gb ram and i work in adobe premiere pro cs2
    if i film with z1 and i want to edit and send it to tv what quality i do for capture and for exporting on hard disk
    merci
  • Pascal Movsessian
    February 17, 2011 at 10:11 am
    merci
  • Yerb Khan
    February 17, 2011 at 6:11 pm
    You have to get this information from the TV station which will broatcast your work. My resolution for that project was 1024×576. Remember mine was going to BETA tape. A technology that is becoming obsolete.
    If you ask me I would do it in 1080p, and then prepare smaller versions like 720p and 576p.
