Activity Forums Adobe Premiere Pro Best Quality Export File
  • Best Quality Export File
    Posted by Doug Broomfield on December 13, 2007 at 9:29 am
    What are thoughts on the best format to export a movie. Uncompressed Microsoft AVI or QuickTime? And if QT, which codec? I have done Uncompressed Microsoft AVI and been pretty pleased with the results. Yes the file size is quite big but I don’t care how big the file size is.
    Mike Velte replied 18 years, 9 months ago 3 Members · 6 Replies
  • Mike Velte
    December 13, 2007 at 11:57 am
    As neither format contains a codec, they should be equal. (Choosing Apple None or Microsoft None as the Compressor)
  • Jeff Brown
    December 13, 2007 at 1:54 pm
    QuickTime with the PNG codec is also lossless, but the (lossless) compression will produce smaller files. Just set quality to 100%.
    I’d vote for QuickTime being more of a “universal” wrapper, but that’s not absolute.
    -jeff
  • Doug Broomfield
    December 14, 2007 at 9:58 pm
    Thanks guys. Looks like from my tests that non-compressed AVI or QT look about the same (which you are right in theory they should). HOWEVER, on the QT export it will NOT let me go past 4 GB. I have read elsewhere that this IS a limitation with PPro 2.0. It is not a FAT or NTSF issue but rather a PPRo 2.0 issue. Adobe says to upgrade to CS3. Anyone else have this problem with QT file size export limit?
  • Mike Velte
    December 15, 2007 at 11:41 am
    The 4 GB limit is the file type; Microsoft AVI and DV AVI along with Mpeg 2 are Open DML files that can exceed Windows 4 GB file limit.
  • Doug Broomfield
    December 16, 2007 at 12:01 am
    So then what you are saying is QT is NOT an open DML file type and thus IS limited to 4 GB in WINDOWS but can exceed 4 GB in the MAC platform? If true it is then both a file type AND platform issue?
    Interesting that Adobe says that they corrected the problem in CS3. I assume they are talking about the windows platform. If that assumption holds to be true then it WOULDN’T be a file type or platform issue, or if it IS then Adobe has figured out a way around it?
  • Mike Velte
    December 17, 2007 at 11:24 am
    It is a platform issue, Apple takes care of its own and so does MS and neither cares much about the other.
