Activity Forums Apple Final Cut Pro Legacy Best ProRes codec for ingest Panasonic AF-101 material
  • Best ProRes codec for ingest Panasonic AF-101 material
    Posted by Geir Ove on February 4, 2011 at 11:51 am
    Hi!
    We are going to use the AF-101 camera on a production.
    They are going to record to the internal SD card on the camera.
    As I understand the bitrate is 24 Mbps, so I’m wondering if I can transcode using the ProRes proxy codec wich is 35 Mbps?
    Are there any disadvantages using the proxy codec instead of LT or regular ProRes?
    Geir Ove
    Dorit Grunberger replied 14 years, 2 months ago 6 Members · 6 Replies
  • Shane Ross
    February 4, 2011 at 11:57 am
    [Geir Ove] “As I understand the bitrate is 24 Mbps, so I’m wondering if I can transcode using the ProRes proxy codec wich is 35 Mbps?”
    Yes. You can convert to that, or LT, or ProRes 422, or HQ. But I really recommend ProRes 422 over Proxy.
    [Geir Ove] “Are there any disadvantages using the proxy codec instead of LT or regular ProRes?”
    It is an OFFLINE editing codec. Meaning lower quality than full resolution. It is designed to save space…you edit offline, lower quality, then capture at higher quality later…ProRes 422.
    Shane
  • Geir Ove
    February 4, 2011 at 12:17 pm
    We where hoping to edit and grade it with the same codec, but I understand that it will take up a lot of space. Understanding what you say we’ll go for an offline workflow.
    Geir Ove
  • Stu Siegal
    February 4, 2011 at 8:48 pm
    Panasonic recommends LT, though it seems illogical that it would have any visual benefit over prores 422, only a file size benefit.
    ftp://ftp.panasonic.com/pub/panasonic/Drivers/PBTS/papers/Editing%20AVCHD%20with%20Final%20Cut%20Pro%207.pdf
    http://www.verite-media.com
  • Jan Crittenden livingston
    February 4, 2011 at 9:49 pm
    If it is only going to be AVCHD on the timeline, LT works fine. It is still 4:2:2. But if you have other codec that will be there or you are really going to shove things around, then HQ, would be better.
    Best,
    Jan
    Jan Crittenden Livingston
    Product Manager, AVCCAM, AG-3DA1, AG-AF100
    Panasonic Broadcast & TV Systems
  • Steve Eisen
    February 4, 2011 at 10:45 pm
    Storage options these days are so very inexpensive.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Dorit Grunberger
    June 22, 2012 at 7:57 pm
    Why?
    Thanks in advance,
    Dorit
