Best project properties and render settings for Vimeo HD?
Posted by Norman Willis on July 7, 2009 at 5:16 pmHello.
What project properties and render settings can I use so that when I upload my project in HD to Vimeo, YouTube and others, that I will not have letterboxing?
Source footage is 1920 x 1080 at 30p.
Thank you.
Norman
Luc Enders replied 16 years, 12 months ago 3 Members · 10 Replies -
John Rofrano
July 7, 2009 at 7:38 pmI believe both Vimeo and YouTube expect 1280×720-30p for HD so this is what i would set my project at and render to.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Norman Willis
July 7, 2009 at 7:57 pmThanks.
The only 1280×720-30p setting I find is labeled “HDV.”
Does it make any difference if my source footage is AVCHD (1920 x 1080)? Or is the “HDV” just a name they tag onto the 1280 x 720 setting, and it really makes no difference?
Luc Enders
July 7, 2009 at 8:17 pmI created a blog entry on this while ago here:
https://lucienk.spaces.live.com/blog/cns!A4AE3FB12A26635!867.entry
Letterboxing is no issue since 1280×720 is same aspect ratio as 1920×1080. Only downside with Vegas is that downscaling is a bit soft compared to Tmpgenc. I do believe though that Vimeo will take MP4 1080p. E.g. choose Sony AVC/MP4 and choose custom and in system tab choose MP4.
Since vimeo now will remove source file after a week for non-plus users I render now as 12M CBR 2 pass instead to get better online quality (but limits # of files obviously).
John Rofrano
July 7, 2009 at 8:27 pm> The only 1280×720-30p setting I find is labeled “HDV.”
HDV comes in two resolutions: 1280×720 PAR 1.000 and 1440×1080 PAR 1.3333.
It will be scaled down to 1280×720.
~jr
Norman Willis
July 7, 2009 at 8:46 pmHi Luc.
Sorry, but I am new, and this went right past me.
What is 12M CBR 2 pass?
Norman
Luc Enders
July 8, 2009 at 1:04 am12M = bitrate (Mb/sec)
CBR = Constant bit rate
VBR = Variable bit ratePasses: 1 pass or multi-pass (Sony supports for couple of formats 2 pass). Multi-pass is necessary for average/peak VBR to first build histogram of scene complexity so it can assign higher bitrates to more complex scenes.
Norman Willis
July 8, 2009 at 1:54 amHi Luc.
I apologize. This one went right past me also.
What is the issue with downscaling being ‘soft’? Does it lessen the sharpness of the image?
And how does Tmpgenc fit into the picture?
Norman Willis
http://www.nazareneisrael.org
servant@nazareneisrael.org -
Luc Enders
July 8, 2009 at 5:15 amSee this thread: https://forums.creativecow.net/readpost/24/895472
Imo Tmpgenc is a great renderer and Sony Vegas is a great editor. So I typically output as uncompressed YUV and then render final output with Tmpgenc as it has more rendering options and good downscale capabilities.
Norman Willis
July 9, 2009 at 3:45 am -
Luc Enders
October 1, 2009 at 11:09 pmYes Tmpgenc Xpress supports H264. Not best editor but definitely great renderer.
