Activity › Forums › Apple Final Cut Pro Legacy › best program for Ken Burns effect and text panning?
James Marshall replied 13 years, 11 months ago 14 Members · 19 Replies
Bouke Vahl
March 15, 2011 at 1:05 pmBut to get it really nice, you need a few layers.
So cut out parts to a new layer, blow up a bit and/or restore the bg.
(Photoshop work probably)
Then go to AE or Maya.Nice example here:
https://www.waanzee.nl/projects/rotterdam_port_experience_-_history/
(I assume this was a week of work at least, see the specs on the final delivery…)
Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Kent Jakusz
March 15, 2011 at 1:09 pmI use PhotoMotion https://www.geethree.com/slickfx/photomotion/
It accepts almost any still format, is easy and quick. -
Cameron Clendaniel
March 15, 2011 at 2:21 pmAE affords the most control but I’ve also used the Pan Zoom Pro FCP plugin in the past, which is relatively quick and easy.
Cameron Clendaniel
film editor, NYC
http://www.camclendaniel.com -
Jonathan Ziegler
March 15, 2011 at 4:56 pmI’ll risk a flame here, but I really like iMovie for this – it’s a built in effect and it’s so easy to use there. Then just export the footage and bring into FCP. I’ve made wedding videos and the like in iMovie many times – it’s drag n drop. I’m using iMovie 7.x (iMovie ’08?).
Jonathan Ziegler
https://www.electrictiger.com/
520-360-8293 -
Jeremy Doyle
March 15, 2011 at 6:27 pm[zeke meginsky] “Is there a way to make sure I’m going straight across without ultra precise mouse dragging (which is close to impossible)?”
Holding down the shift key will lock you down horizontally or vertically depending which way you are dragging with your mouse.
Zeke Meginsky
March 15, 2011 at 6:47 pmThanks, I’ll try that shift key thing.
I’m going to try to use Motion tonight. Is there something I should be doing with the images first before I do it? I read somewhere that I should convert them to .tiff, not .jpeg. Should they be certain dimensions (resolution) and is there a way to make them certain dimensions?? Thanks so much for anyone who responds to these questions..
Zeke Meginsky
March 15, 2011 at 6:49 pmDo you get a lot of control with I Movie as to where it starts and stops and how long…?
Noam Osband
October 4, 2011 at 8:25 pmI’m about to use Motion to do some Ken Burns effect styling. Any advice, Zeke? For that matter, in a question for everyone else, is using Motion any better than using FCP with the Noise Industries Pan and Zoom free plug-in?
James Marshall
October 28, 2012 at 9:54 pmThis is probably a bit late, but I have used most of the options FCP, avid pan and scan, motion and AE and the best bit of software out there for this is Digirostrum from cleverplugs. it costs a bit £300 or so but it offers so much more than in out up down left and right. It is also pretty easy to use and out puts most formats. I often work with massive stills and have problems with fcp and avid crashing and motion scales them to only 4000 pixels wide.
good luck
james
James 🙂
