Activity Forums Canon Cameras Best Pro Camcorder for use with Adobe CS6
  • Best Pro Camcorder for use with Adobe CS6
    Posted by Norman Willis on December 31, 2019 at 10:24 pm
    Hi. I am a content provider and alleged “talent” who also does all the purchasing.
    Right now we have a volume license for Adobe CS6. I don’t have money to upgrade it for the whole crew. Right now I have some AVCHD cams (Canon HF-S10s) that send a real pretty uncompressed picture out the HDMI port in studio. I am happy to keep using them in studio, but I need something better than AVCHD for field recording. I called Canon and they recommended the XF-405, which I thought looked great, but it records in MP4, and when I researched it, Adobe CS6 has had some issues consuming MP4 in the past. I don’t know if it still does. I suppose I could convert the footage, but I could also buy a slightly older Canon camera which outputs a format that Adobe CS6 supports. (I imagine that Adobe will probably not want to tell me. Adobe will want me to buy Creative Cloud, which I would love, if I had the money.) So does anyone know which Canon formats CS6 supports? And which Canon codecs definitively work in CS6? Thanks very much for any help or pointers.
    Norman B. Willis
    Apostle, Nazarene Israel
    The original faith of the apostles,
    as found in Acts 24 and 28
    http://www.nazareneisrael.org
    Norman Willis replied 6 years, 7 months ago 2 Members · 3 Replies
  • Norman Willis
    December 31, 2019 at 11:26 pm
    P.S., these are the specific codecs I am curious about, if they will work in CS6 (or not).
    MP4
    MPEG2
    XF-AVC
    XF Codec
    MXF
    Thanks very much.
    Norman B. Willis
  • Todd Terry
    January 5, 2020 at 5:53 pm
    Hi Norman…
    Unfortunately there might be a little bit of trial and error involved. I am also a CS6 user… we can’t upgrade our suites to CC because they are Matrox-based machines, and unfortunately Matrox doesn’t support Premiere past CS6.
    At first blush most of those codecs should work in CS6. However, should doesn’t necessarily mean will. For example, we primarily use the Canon C300PL, which generates .MXF files. However, on occasion we also use a little XC15 as a B-camera, which also generates .MXF files. While we can import the C300 footage directly into CS6 with no problem, we cannot import the XC15 files, even though they are also .MXF files.
    We have to convert those files, and run them all through Handbreak… and then the imports work just fine.
    That’s a very long way of saying “It’s impossible to tell… exactly” regarding your questions about the various codecs.
    What I’d suggest you doing is once you settle on a camera or two that you are definitely considering, asking people here at the COW and elsewhere on line if anyone can send you a direct-camera-raw file from that camera… that way you can test it with the “real deal.” Just make sure they are sending you the actual camera-generated file (even just a few seconds is fine), and not something that has been processed or converted in any way. I’ve had luck doing this, people are very helpful and generous….assuming they had that particular camera, of course.
    Obviously you can always convert footage to make it perfectly usable (as I said, we use Handbreak which is completely free and GREAT and easy to use), but of course being able to directly use the footage is much easier.
    Good luck,
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    fantasticplastic.com
  • Norman Willis
    January 6, 2020 at 3:05 am
    Todd, thanks for your encouraging post.
    Due to a variety of other factors, I went ahead and ordered the camera. I think we are going to try to transition to Resolve, and then use Photoshop and AE to augment. And we can rent AE2020 by the month for whatever we cannot learn to hit with Resolve. And if we cannot transcode with Resolve or Handbrake, there is always VideoProc (which is not too expensive). So we should be able to hit it.
    Thanks again.
    Happy editing.
    Norman B. Willis
