Activity Forums Adobe After Effects Best practices to build animations as neat, small files.
  • Best practices to build animations as neat, small files.
    Posted by Kris Rost on December 2, 2015 at 11:01 pm
    My first AE animation project is finished @ 58 sec, 21.6MB after Handbrake, embedded into an app created in Ionic frameworks not available in either app store.
    This Ionic build would not (i was told} be able to rotate, so the animation was 1080 x 1920. I created all the simple art in Adobe illustrator imported and placed as .ai files; with proper layers, and imported suchly… etc. Some scenes were quite large as they had zooming parts to tell the story.
    The purpose was as a “motivational” on-boarding intro to the app and afterwards my epic video would never be seen again in the app.
    I don’t really know if I bloated the animation’s file size or not. I would really like to know what I could have done differently, can I still change and reduce things?
    So I am asking for some reference material to consult for future projects which I will be called upon to create; to build animations as neat, small files.
    I DID look for commonly asked questions, but all the ones I found were about optimizing.
    I think I get that through using Handbrake.
    The AE rendered QT file was 920.7MB. After Handbrake it was 21.6 MB
    Thanks for any advice,
    Kristina
    Ivan Myles replied 10 years, 9 months ago 2 Members · 5 Replies
  • Kris Rost
    December 3, 2015 at 4:26 am
    I supplied them according to their specs. The had nothing to say about codec. Their specs were handbrake specs…
    my question was asking about building art and animations, about creative process guidelines for leaner arts before rendering… not compression or output of the finished rendering. I am looking for some tips and tricks for building animations for a lighter file size before render output?
    Could I have created the illustrator art differently for an AE project to make a smaller file?
    For instance…the first draft of the animation was 38 seconds…then the client made changes and the animation became 58 sec to slow the voice over down with longer pauses. The first 38sec had no problem embedding…@12Mb. The 58 sec version was 2x the size and the app choked…but we were eventually able to get it to embedd. Could/Can I do something to make the art works a leaner And smaller file to render?
    Thanks for your response.
  • Ivan Myles
    December 3, 2015 at 6:15 pm
    [Kris Rost] “Could I have created the illustrator art differently for an AE project to make a smaller file? … Could/Can I do something to make the art works a leaner And smaller file to render?”
    Simplify as much as possible in the artwork and the animation. For example, minimize gradual changes in-frame (gradients) and frame-to-frame (fades, rotation, zoom) where the encoder can’t reuse the image easily. Here are a few ideas:
    – avoid gradients and subtle color variations; use solid colors or simple repetitive patterns; use fewer colors
    – panning is OK but avoid rotating the camera (either pivoting or rotating axially in the plane)
    – use clean cuts and avoid fades or cross-fades
    – avoid slow zooms
    – reduce the number of unique items; repeat the same objects in different places, and use fewer of them
    – go retro: blocky, low-resolution graphics with simple motion
    You mentioned that there are zooms in the animation. Try to simplify by holding frames at a small number of intermediate zoom levels and jump from one to the next (“stutter zoom”). Alternatively, use a pop-up bubble to show specific areas at higher magnification in front of the same unzoomed background.
  • Kris Rost
    December 3, 2015 at 6:23 pm
    Perfect!
    I am not sure the dev guys really knew all the options. We will look into this and have go!
    Thank you very much.
  • Kris Rost
    December 3, 2015 at 6:27 pm
    All my imagery was flat vector shapes…so I was good there.
    Your suggestions about zooming was Great!
    I had a text fade in and one graphic fade in… maybe
    Anyway I am going to try all of these suggestions on sandbox versions.
    Thanks a lot!
  • Ivan Myles
    December 3, 2015 at 7:31 pm
    You’re welcome. Also, if there isn’t a lot of motion/change then consider using a longer keyframe distance for the final encoding (60-75 frames). Try a few settings and check for differences in file size and image quality. Note that once keyframe distance is greater than one second of footage the reduction in file size will be relatively small.
