Activity › Forums › Adobe After Effects › Best possible settings to export for YouTube HD (720p)?
Posted by Georgina Lord on June 10, 2012 at 10:09 amI wonder if anyone could give me some tips on the best way to encode a video in AE/Media Encoder (CS5.5)so that it looks as good as I can get it for uploading into YouTube @ 720p? Granted I realize that YouTube doesn’t exactly offer anything like superior HD quality, but for some reason I just can’t seem to be able to encode my videos so they looks as smooth/good as a lot of YouTube HD videos I’m seeing out there.
G.
Daniel Horn replied 10 years, 10 months ago 5 Members · 7 Replies -
Georgina Lord
June 10, 2012 at 10:29 amMy apologies; I see there is a “Compression” forum. I should have posted this there. Still, if anyone has a clue… 🙂
Tudor “ted” jelescu
June 10, 2012 at 4:44 pmEither render uncompressed from AE and use a compression soft, like Adobe Media Encoder to compress to a H264, mp4, f4v or flv container, or just open the AE comp in Encoder and render straight from there.
Use Variable bit rate, two pass and if you have gradients and lots of motion, keyframe every frame.Tudor “Ted” Jelescu
Senior VFX Artist -
Georgina Lord
June 17, 2012 at 12:16 amThank you. I tried several methods, including the setting you advised, all with key frames on every frame, but although the material looks absolutely perfect offline, YouTube just makes it looks like crap. I know it can do better than what I’m getting as I’ve seen other YT videos that look great.
I tried QT @ 100% quality + 1 keyframe every frame, I tried the same with h.264, even going up to an over-the-top 60mbps and 1 key frame every frame, also tried uploading the a full lossless avi (1.54gb for a 20 second 720p clip) and they all looked pretty dire.
Tudor “ted” jelescu
June 17, 2012 at 11:59 amThat is strange- are you sure you are looking at them at the best possible resolution in YouTube? Also, you’re aware that it takes a bit longer to have access for all resolutions once you post a clip on YouTube, right?
Tudor “Ted” Jelescu
Senior VFX Artist -
Todd Kopriva
June 18, 2012 at 1:17 amHave you tried the YouTube encoding presets in Adobe Media Encoder? We worked directly with Google/YouTube to get these perfectly aligned with their specs for Adobe Media Encoder CS6.
product manager, professional video software
After Effects team blog
Premiere Pro team blog
Robert Jones
May 21, 2013 at 3:15 pmI am having the same problem. I use media encoders 23.96 fps 720p youtube preset and when I put it on youtube its not smooth like other videos I watch. My sequence preset used these settings but there are clips from various frame rates. Most of my clips are 23.96 720p but a few are 30fps and/or 1080p. It’s all movie clips. Some I guess came from TV and therefore are 30 fps.
I’ve played it back on my computer at home and also at work where we have really good bandwidth. Click on the video below to see for yourself. What I don’t get is how smooth other peoples videos are by comparison. Any help would be greatly appreciated!
https://www.youtube.com/watch?v=o96uZ9ZDr3M
Click above!
Daniel Horn
October 31, 2015 at 11:04 pmIt often takes 10 minutes or so, sometimes even an hour for videos uploaded to youtube to fully process and be available in their highest quality setting. Maybe that’s your problem?
