Activity Forums Panasonic Cameras Best Picture Quality?
  • Best Picture Quality?
    Posted by Southern Videography on August 14, 2006 at 8:12 pm
    I want to get the best picture quality out of my HVX200. I shot some test video in Video Cam mode, 1080 60i to a FS-100. The setting on the FS-100 was DVCProHD. I imported the footage into FCP 5.1 and placed it in a DVCProHD 1080 60 timelime. The clips did not need to render. I exported the video using compressor. The setting was the DVCProHD 1080 60 setting under the advanced settings. After the export I brought the video into DSP4 and tried to burn. I got a message saying video bit rate too high. So apparently I am dooing something wrong. I don’t have an HDDVD burner I am burning in SD. What do I need to do to get the best picture quality possible? I work on an Intel G5 FCP 5.1.1, DVDSP4 and QT 7.1.2…any suggestions?
    Uli Plank replied 20 years, 1 month ago 3 Members · 5 Replies
  • David S.
    August 14, 2006 at 10:47 pm
    Export to current settings, self contained, audio and video.
    Drop that into Compressor, and elect a m2v/mpeg2 setting consistent with the length of the video in total minutes.
    Elect the Dolby2 settings for audio.
  • Southern Videography
    August 14, 2006 at 11:27 pm
    Thanks, I’ll give it a try.
  • Uli Plank
    August 15, 2006 at 6:45 am
    Since your DVD will be in SD, do yourself a favor: drop the HD footage into a SD sequence (no DV codec, rather uncompressed or Photo-JPEG@75%) and let FCP to the scaling (set the scaling quality in the render settings to high).
    Render and export the sequence as a referenced file and then drop it into Compressor with a proper preset (as described here). It’ll be much faster and excellent quality.
    Regards,
    Uli
    Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
    August 15, 2006 at 1:43 pm
    Uli, do I want to export using one of the Advanced Format Settings like uncompressed 8/10 bit or an HD uncompressed or one of the DVCProHD settings, or do I want to use Best Quality 90 min 16:9?
    Thanks for your help!
    Scott
  • Uli Plank
    August 15, 2006 at 2:13 pm
    Don’t export in Compressor at all, that’s slow. Export a QT movie after setting the timeline to one of the codecs I mentioned. Uncompressed 8 bit can’t hurt, 10 bit is overkill. The QT movie doesn’t need to be self-contained.
    I suppose you want to burn a DVD that can be played in todays SD players, right? So just use the best settings for the duration you have. That’s all.
    Regards,
    Uli
