Activity › Forums › Adobe Premiere Pro › Best path for scaling down Prores HQ to Mpeg2 files for DVD
  • Best path for scaling down Prores HQ to Mpeg2 files for DVD
    Posted by Matt Stoddart on October 29, 2012 at 2:10 pm
    I have always gone one route when encoding ProRes HQ 1920×1080 files to Mpeg2 720×576 for use in Encore.
    1) Create a new sequence in Premiere CS5 (DV widescreen 48k),drop the ProRes file on to the timeline and reduce the scale by 55%, then render out with both “Render at max depth/scaling” ticked.
    I’m please with the end results, usually 18 hours later on a 90min film, but in the search to reducing any aliasing in the usual shots (blinds, french sweaters etc) should I go a difference route?
    Does anyone place the HD file on a HD timeline and render straight from that just using the output cropping tool to elimate the pillarboxing?
    Thanks in advance.
    Matt Stoddart replied 13 years, 11 months ago 3 Members · 5 Replies
  • Kris Merkel
    October 29, 2012 at 2:30 pm
    Is there any reason why you do not want Adobe Media encoder to do the heavy lifting (Compression) for the PAL DVD MPEG-2 files?
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    Blackmagic Design UltraStudio 3D
    AJA IO XT
    FSI LM-2340W
  • Matt Stoddart
    October 29, 2012 at 2:51 pm
    Thanks Kris,
    I do let AME do all the heavy lifting, I just use Premiere to scale it down and do any 24 to 25fps adjustments I need to before sending it to the queue in AME.
    Cheers
    Matt
  • Kris Merkel
    October 29, 2012 at 3:12 pm
    You might see better spatial results if you do the scaling in AME as part of the encode. As far as speed increases I couldn’t say one way or another because this is not a workflow that I use. I do however always let the encoding tool, AME, Compressor, Episode ect do the scaling of the final output.
    Kris Merkel
    2.2Ghz MBP core i7
    16Gb RAM
    CS 5.5
    FCP7 and Studio
    AJA IO XT
    FSI LM-2340W
  • Mike Squires
    October 29, 2012 at 9:57 pm
    Why not send your HD sequence straight to Encore (via Dynamic Link)? This will use AME to do the scaling.
  • Matt Stoddart
    October 29, 2012 at 10:27 pm
    You still have to crop the top/bottom of a 1920×1080 frame to get a 720×576 (1.46)frame without any pillarboxing, 15 top and bottom in the crop function on the source/encode window seems to do the trick.
