Activity › Forums › Adobe After Effects › Best output / compression settings for After Effects
Posted by Judie Luszcz on November 19, 2009 at 10:34 pmAnyone know of a resource for render / compression settings out of After Effects? I’m looking for more info on keyframing and data rate limits, specifically the best output settings for Animation, DV, H.264, the whole output drop-down list. I’m really hoping for chart form for an easy read. Suggestions?
Todd Kopriva replied 16 years, 9 months ago 6 Members · 5 Replies -
Walter Soyka
November 19, 2009 at 11:47 pmLike Dave said, there is no “best” compression setting. Your compression settings will be determined by your delivery requirements.
With that in mind, AE has many strengths, but compression is not among them. It is not capable of multi-pass encoding, which is critical for quality output with highly-compressed, variable bit-rate encodes. I tend to render to lossless image sequences or lossless Animation in AE, and then use a third-party compression utility. There are many contenders here: Compressor, Episode, Squeeze, ProCoder, etc.
Walter Soyka, Principal
Keen Live, Inc.
Presentation, Motion Graphics & Widescreen Design
RenderBreak: A Blog on Innovation in Production -
Kurt Larson
November 20, 2009 at 3:40 amheres a nice little article i know of that goes a little in depth of each compression. hope this helps
https://ae.tutsplus.com/articles/in-depth/the-after-effects-output-module-exposed/#more-1886
Juan A. ibarra peinado
November 20, 2009 at 8:19 amMay the only one “universal best compression” is “AVI or QT uncompressed” ^^
CÁMERA: JVC GYHD251+BR-HD100
VTR: JVC BR-HD50
CAPTURE PLAYBACK: BLACKMAGIC MULTIBRIDGE PRO
COMPUTER: I7 -
Steve Roberts
November 20, 2009 at 2:22 pmAnimation: try just below 100%.
DV: I thought there were no choices …?
Photo-JPEG: move the slider off 100% — it usually stops aroun 89-91%.
TGA: leave it alone.As for anything else like H.264, the other gents are right: don’t use AE. AE is good for rendering to high-quality, then you use something like Sorenson or Compressor to do the 2-pass encoding.
Speaking of which, compression is considered an art, and if you want to learn more, look on the Compression techniques COW.
Todd Kopriva
November 21, 2009 at 12:55 amActually, that article has quite a few problems.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
