Activity › Forums › VEGAS Pro › best options to render to a DVD quality file
  • best options to render to a DVD quality file
    Posted by Daniel Valencia on February 9, 2011 at 11:25 pm
    Hello
    What are the best rending settings to export my videos (HQ) if a need to create a widescreen presentation.
    So far everything l can get on widescreen but when i burn it to disc it actually keeps the size that is meant to be for example if l render it to a 1080×720 and l play it in my 50inches Tv is too wide and leave black parts on the sides too.
    What are the best settings rendering for a DVD video output
    By the way l sdo check the ” stretch media to match output”
    thanks
    John Rofrano replied 15 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    February 10, 2011 at 12:48 am
    [daniel valencia] “What are the best rending settings to export my videos (HQ) if a need to create a widescreen presentation.”
    You want to render the video using the MainConcept MPEG2 codec using the DVD Architect NTSC Widescreen video stream template and render the audio separately as Dolby Digital AC3. If you live in a PAL country use the PAL template instead.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
