Activity › Forums › Apple Final Cut Pro Legacy › Best open timeline for mixing DVCAM w/DVCPRO HD
  • Best open timeline for mixing DVCAM w/DVCPRO HD
    Posted by Aaron D hose on September 1, 2007 at 5:02 pm
    Hi to all.
    We’re in the middle of editing a project where we need to combine DVCAM footage with 720p/24PN/60fps and 1080i/60 inserts (all inserts were shot with an HVX200 and brought into FCP6 via P2Store). Since most of the footage in the edit is DVCAM and we’re ouputting to SD DVD, here’s the open timeline we chose:
    – DV/DVCPRO NTSC
    – 720×480
    – D1/DV pixels
    – 29.97 fps
    – Lower field
    – Render all YUV material in high precision YUV w/motion tab filtering set to “best” (this for when we color correct)
    However, we’re not very happy with the way the HD shots are resized on the open timeline. There’s some minor aliasing in the HD clips, and while the slo-mo shots look good, they’re not as slick as I had hoped for. There’s some minor stuttering in the video.
    Any suggestions? Should we be using different settings for our Open Timeline, or are we stuck with doing it this way?
    What about color correction? We’re planning on upressing to DVCPRO50, Uncompressed 8-bit or 10-bit, or ProRes422 and mastering to DVD from there. Which one works best?
    Any pointers are highly appreciated. 😉
    Thx in advance
    Aaron
    John Pale replied 19 years ago 3 Members · 2 Replies
  • Chris Borjis
    September 1, 2007 at 5:53 pm
    On thing I can think to remove the aliasing is set the motion quality for FAST. As odd as it seems, this fixes all the aliasing issues I have when clips are resized in fcp. Sometimes though the aliasing goes away further if you render out your timeline. The viewer will not show this improvement until you render out a completely separate file.
    Everything else sounds right, make your timeline the same size/codec as the majority of your mixed footage is to ease the pain during the process.
    as for color correction, I would render out the timeline to ProRes or uncompressed to keep image degradation to a minimum.
  • John Pale
    September 1, 2007 at 5:54 pm
    Try applying the shift fields filter to the HD footage, if FCP has not done it automatically.
    HD is upper field first, while DV is lower. That could possibly be the source of your aliasing and stuttering…maybe.
