Activity › Forums › Adobe Premiere Pro › Best OLDER version of Adobe Premiere for the Mac Should I Get?
  • Best OLDER version of Adobe Premiere for the Mac Should I Get?
    Posted by Steve Crow on February 27, 2014 at 12:51 am
    I currently have a mid to late 2006 Macbook Pro with the following specs:
    OS x version: 10.6.8
    Model Identifier: MacBookPro2,2
    Processor Name: Intel Core 2 Duo
    Processor Speed: 2.33 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 4 MB
    Memory: 4 GB
    Bus Speed: 667 MHz
    ATI Radeon X1600:
    Chipset Model: ATY,RadeonX1600
    Type: GPU
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    So I have a client that is considering standardizing on Premiere Pro because they are on PCs. The video editing projects are not complicated. So my question is:
    * Given the specs of my older Mac, which version of Adobe Premiere Pro would be best for me to install?
    * Will my client, with a much more modern version of Premiere on the PC, be able to open my Premiere project files from the Mac which will be from a much older version?
    Buying a newer Mac is probably not in the cards for me until a bit down the road, so I need a solution to get me through the first few months…thanks for your advice in advance
    Steve
    Steve Crow
    Jeff Meyer replied 12 years, 7 months ago 2 Members · 3 Replies
  • Jeff Meyer
    February 27, 2014 at 12:59 am
    With Premiere you need to stick to the same version. If you don’t you’ll be stuck on XML. So if they have CC you need CC, if they’re on CS6 you need CS6. I’ll let you check compatibility between that software version and your own system.
  • Steve Crow
    February 27, 2014 at 1:03 am
    Is there any chance that Premiere Pro CC on a PC will be able to import/open project files from Final Cut Pro 6 on a mac? If so then maybe the whole issue is not really one after all?
    Steve Crow
  • Jeff Meyer
    February 27, 2014 at 1:05 am
    Premiere CC will happily take a Final Cut XML. Expect edits to be along for the ride, but don’t plan on text or effects traveling. Transitions and audio tracks will be hit and miss. I would advise against considering it a back-and-forth workflow, consider it a one time conversion.
