Activity › Forums › Apple Final Cut Pro › Best Music Settings?
Posted by Eddie Valentin on January 30, 2026 at 1:46 amBest still image music settings for final cut pro 12
Ben Balser replied 6 months, 3 weeks ago 2 Members · 3 Replies -
Ben Balser
February 4, 2026 at 8:11 pmDo you mean for sill images and for audio files? Still images should not be much larger than the frame size of the Project they’re being used in. The exception is if you plan to enlarge them to zoom in on them, then make them a bit larger. For a 1080 timeline, 4K should be fine for a still image. And at 75dpi.
As for audio files, depends how you get them. What format are they in? What bit-rate, what sample rate? Converting an audio (or video) file to a better codec doesn’t make them better.
Eddie Valentin
February 18, 2026 at 1:13 amyes, audio and image. im exporting pro res 422 and which is best for sound quality? better performance or better quality. sorry for late reply
Ben Balser
February 24, 2026 at 11:56 amVideo codecs won’t affect audio quality at all. Audio will stay the same.
