Activity Forums Compression Techniques Best .MOV format under 60 mbs
  • Best .MOV format under 60 mbs
    Posted by Aryn Leigh on May 17, 2011 at 10:30 pm
    I’m looking to compress a 5 minute edit (edited at 720p 59.94 DVC pro 960×720)for the web. The limitations on the site require it be less than 60 mbs. (?!) I’d like to keep it as close to the original size as possible (wishful thinking)and also with as little quality loss as possible. What is the best .MOV format to try in compressor?
    -AL
    Jeff Greenberg replied 15 years, 4 months ago 3 Members · 2 Replies
  • Craig Seeman
    May 17, 2011 at 11:34 pm
    Please consider using BitRate Pro to calculate the needed data rate.
    https://www.pimley.net/projects/
    At a combined 1600kbps it might be OK depending on the content otherwise you might have to go to a smaller frame size.
  • Jeff Greenberg
    May 18, 2011 at 1:34 pm
    Just to follow up on what Craig said.
    It’s going to be an h.264 file. At that size, a bitrate calculator returns a rate of 1,600 kbs to be at 60megs.
    I’d run that through whatever compression tool you have…and if you’re not happy with the results, essentially there are three things you can change:
    The frame rate, the picture size and the bit rate. Since your bit rate is limited, I’d suggest cutting the data rate in half first to 29.97 fps.
    Let us know how it goes!
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
