Activity › Forums › Apple Final Cut Pro Legacy › Best Monitor for Under $400
  • Best Monitor for Under $400
    Posted by Jason Presser on January 18, 2008 at 1:43 pm
    I’m buying a Mac Pro and looking at the Dell E248WFP. Any thoughts on it? What do I lose if I don’t get the Ultra Sharp? Should I go for a smaller monitor w/ more functionality? Thoughts? Thanks.
    Mark Palmos replied 18 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Biscardi
    January 18, 2008 at 2:33 pm
    [Jason Presser] “I’m buying a Mac Pro and looking at the Dell E248WFP. Any thoughts on it?”
    Terrible. We’re returning ours. Could never get the blacks to look anything other than crushed. We have the 2407WFP and were about to go ahead and order another one, but we found a 24″ Samsung in Costco that is working out quite well. Still not exactly the same quality as the 2407WFP, but much better than the Dell.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Paul Escandon
    January 18, 2008 at 5:46 pm
    The UltraSharps use S-IPS panel technology which is going to be of a much higher quality than the lower end cheaper monitors which are usually using TN panels. This is significant to the video editor or graphic designer who cares about true color representation and fidelity. As Walter’s experience shows, you will definitely lose quality when going with a TN display. If you’re considering Dell’s I would ONLY ever look at the UltraSharps. You might not see a big difference on the spec sheets, but it’s there.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    http://www.oremusproductions.com
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Jason Presser
    January 18, 2008 at 9:47 pm
    do you think I would be better off with the 22″ Dell Ultrasharp? I’d like to avoid spending $700 on a monitor if I can. What do you recommend?
    https://accessories.us.dell.com/sna/products/Displays/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=320-6107
  • Walter Biscardi
    January 18, 2008 at 9:49 pm
    I would probably go for the smaller ultrasharp model. Your eyes will thank you. You can always add the 24″ later as a second monitor.
    Read my Blog!
  • Mark Palmos
    January 31, 2008 at 10:41 am
    Paul, Walter and others,
    Ive been looking at the Dell Ultrasharp 2407 too, but what strikes me is AFAIK all these computer monitors do not show inerlaced footage as interlaced, but only show progressive… so if you happen to have your field order messed up, it will be hard or impossible to notice, till you watch it on an interlaced monitor.
    SO
    Wouldnt an LCD TV be the best option for low cost monitoring?
    If so, do you have any suggestions for a 24 inch monitor that shows interlaced footage as interlaced?
    TX
    Mark.
  • Walter Biscardi
    January 31, 2008 at 10:56 am
    [Mark Palmos] “Wouldnt an LCD TV be the best option for low cost monitoring?
    If so, do you have any suggestions for a 24 inch monitor that shows interlaced footage as interlaced?”
    Only if you want to spend at least $2,000 for a TV Logic LCD.
    If you want to simply check interlacing order, especially for standard def, simply go to any electronics store and pick up the cheapest CRT TV you can buy. Any of those will show you if something is out of whack in interlace order.
    Read my Blog!
  • Mark Palmos
    January 31, 2008 at 11:26 am
    Hi Walt
    yeah, ive got a Sony PAL component monitor already, but thats SD, I was thinking to be able to monitor 1920×1080 interlaced.
    I guess I could have some down converter for the fields thing, and a Dell to see a pretty picture.
    Catcha later
    Mark.
