Activity › Forums › Adobe Premiere Pro › Best method to obtain “cool” look
Posted by Duke Sweden on June 5, 2017 at 2:48 pmI’ve noticed that when I “warm” up my video it looks really nice, very filmic and rich. But when I try to get a “cool” atmosphere it always looks like poorly white balanced video. I’ve followed countless tutorials but always end up with the same result. Any of you pros feel like sharing some tips. This is working with h264 4K footage, correctly white balanced Cinelike D.
Chris Wright replied 9 years, 3 months ago 6 Members · 5 Replies -
Jon Doughtie
June 5, 2017 at 7:47 pmDo you have Photoshop? You can create you own lumetri looks in Photoshop, then use them in your footage.
Basically, you grab a still from your timeline, pull it into Photoshop, and start playing to get the look you like.
Details here – https://www.youtube.com/watch?v=v4XPi_aMBZ8
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF.Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tero Ahlfors
June 6, 2017 at 7:13 amTo make a “cool” look you probably wouldn’t want to smack an overall coolness to it but do it to a certain part of the image. For example keeping the skin tone normal will give a pretty interesting look if the image is overall greenish/blueish. Dunno how much this is actually doable in Lumetri because IMO it’s really terrible when it comes to any kind of secondary color correction.
Ben Walters
June 6, 2017 at 11:14 amOnce you “cool down the footage”, i would recommend doing a secondary and warming up just the skin tones. That should give you a more balanced image.
Chris Wright
June 6, 2017 at 12:07 pmhow are you getting the look? if you apply a blue tint, then everything will wash out and look flat. if you offset the white balance you’ll get a much better result as all colors will rotate at the same rate. better still, use an alpha matte on keyed red channel, and a blue/green on the other channels. this separates actors from the background.(you need to soften the matte to not get pixellation for this to work). you can try a lumetri secondary color correction in premiere but I find adding a thousand special procedural grading effects in premiere super cumbersome.
I neutralize all my clips to one standard with premiere’s scopes, them render out for AE. Since everything now matches, I just drag sliders around like a plugin till I get the look I want. It’s like a poor man’s magic bullet.
My AE technicolor aep has a built in tint red channel precomp you can enable or you can try a lumetri secondary color correction.
ae 2015cc effects built in: techicolor, smart luma, smart sharpen, red tint, background tint, glow rolloff.
https://f1.creativecow.net/file.php?id=9780&folder=ae-technicolor-cc-2015
