Activity › Forums › Adobe Premiere Pro › Best method to export M2V from captured digibeta footage?
  • Best method to export M2V from captured digibeta footage?
    Posted by Sloan Warner on December 16, 2006 at 6:10 am
    Hey all,
    I have 2 NTSC projects; both captured via a decklink card from digibeta (one uncompressed, the other motionjpeg). After some small color adjustment and edits – i’m exporting these to m2v & then to encore. When I export it lower field (the default) CBR 7m or VBR 7m the final dvd looks good on some players & all computers and awful (deinterlaced ghosts) on others. Deinterlacing exports seem to look good – but something tells me that isn’t the way a finished DVD should be exported from a source like this.
    Would importing the captured video straight into encore yield a better result? Should I be using upper field exporting (not doing this as I thought NTSC was low and PAL up). I’m using the out-of-the-box Adobe Media Encoder.
    Anyhow, appreciate any advice and help in advance … driving me a bit crazy.
    S.
    Sloan Warner replied 19 years, 9 months ago 3 Members · 5 Replies
  • Mike Velte
    December 16, 2006 at 2:37 pm
    While Digital Video (DV) is lower field first (NTSC and PAL) all bets are off on analog video. Its pretty obvious (on a TV) when the fields are reversed…motion is real jittery. A PC monitor cannot be useful to determine if the video is interlaced and if the field order is correct.
    With 2 different sources, I would experiment with a short DVD with a bit off both sources to be sure. To deinterlace or not is a personal choice, the look is slightly different on a TV, but niether is wrong.
    Encore and Premiere use the exact same encoder with the same settings, so I export from Premiere as Mpeg and author in Encore for Dolby and other options that Premiere authoring lacks..
  • Sloan Warner
    December 16, 2006 at 6:16 pm
    Thanks for the response. Appreciate it. I had deinterlaced things in the past that were ultimately meant for a computer playback – definitely a choice on which way you want the motion to look.
    For telling if the field order is correct, how would you notice on a monitor? Should there be no obvious signs if the video was exported proper?
    S.
  • Vince Becquiot
    December 17, 2006 at 12:43 am
    The most obvious effect of a reversed field order will be stuttering in motion areas, and pans.
    Vince
  • Mike Velte
    December 17, 2006 at 11:53 am
    Viewing interlaced video (proper field order or not) on a progressive scan device such as a PC monitor will not help with diagnosis of field order.
  • Sloan Warner
    December 19, 2006 at 12:38 am
    Thought I’d update on my tests and what I found. Hopefully it will help someone? Perhaps someone has something to add?
    Anyhow. I exported my footage captured by premiere as mjpeg footage (what it was when I captured). I set it as upperfield (even though it claims it’s lowerfield). I then import that AVI into encore – when encore transcoded this it looks correct. No M2V I exported from Premiere looked good on a standalone unless I de-interlaced it. I will note – I was cropping the output from premiere …. note sure if this messes up the field order? Perhaps I should have ‘clipped’ instead?
    ideas, solutions. Thanks for the replies!
