Activity Forums Apple Final Cut Pro Legacy Best method to compress DVCPRO HD to DVD?
  • Best method to compress DVCPRO HD to DVD?
    Posted by Barlow Elton on August 17, 2005 at 4:37 am
    Poste this also in Compression techniques forum…
    I need to convert a DVCPRO HD 23.98p clip into a properly cadenced NTSC clip, and then convert to DVD. I’ve tried downconverting the clip in a FCP DV timeline, and while the program will properly letterbox the footage and convert to DV, it adds an incorrect 2:3 pulldown cadence that can be fairly annoying to watch.
    I know it isn’t ideal to convert to DV and then to MPEG 2, but I thought it would be a simple way to make a decent quickie DVD. I can use FCP or Compressor and covert to any QT codec, but does anyone know the best method to create a proper pulldown of the footage?
    Thanks for any reply.
    Barlow Elton replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
