Activity › Forums › Adobe After Effects › Best method of adjusting footage for projection on colored wall?
Posted by Brittnell Anderson on October 4, 2012 at 6:53 pmI have a video that I know will be projected on a yellow painted wall.
Any thoughts on the best solution to knock down only the yellow channel, so that it appears more balanced once projected?
Jeff Brown replied 13 years, 11 months ago 5 Members · 5 Replies -
Cassius Marques
October 4, 2012 at 7:33 pmDid you tried the selective color effect? It has some nice controls.
Brittnell Anderson
October 4, 2012 at 8:28 pmGreat suggestion, thanks.
I am testing it out now, but already feel this might be the best solution.
Now the challenge will be finding the specific adjustments necessary for this projector/wall color combination.
Cheers! -
Chris Wright
October 5, 2012 at 1:49 amSome expensive projectors have a wall shot button that white balances automatically. i.e. You see a sequence of colors flash for approximately five seconds while the sensor measures the conditions of the projection surface and adjusts the image.
IF you don’t have that feature, you can eyeball it with selective color or try my auto w/b.
I wrote a project a while back that will automatically remove tints of any color. It also works on incorrect camera settings and old film.
1. just record the projected image on the yellow wall with a camcorder then import and replace the video in the project. It has optional furthur tweaking on master control sliders. (important! Stretch it to the exact size!)
2. copy and paste all layer 6’s effects onto your final out comp. The remove tinting effects will now proactively remove themselves before it’s even projected onto the wall.
auto white balance shadow.aep
ae cs3.zip
https://www.mediafire.com/download.php?5vkfg7ash7tgvj7 -
Jim Arco
October 5, 2012 at 12:52 pmIt sounds like you want to modify the footage so it looks correct when projected on the yellow wall.
So, you want to ‘subtract’ the yellow from the existing video. To be accurate, you need to subtract the specific yellow that is on the wall.
The technically accurate method would be to determine the exact hue of the yellow wall. Use a calibrated color meter (yeah right) or accurately balanced camera and vectorscope. Then subtract that hue from the image (or add the same amount of the opposite hue -blue in this case- to the image.)
One method: Have the projector show a white frame on the wall, shoot it (still cam would probably be OK), then put that footage in your project and ‘subtract’ the color by inverting (ctrl-I) the footage. Adjust opacity to suit.
Jim
Jeff Brown
October 10, 2012 at 2:32 pmThe direct way:
Buy an assortment of theatrical gels in the blue/cyan range.
Hold in front of projector. Pick best look. Add sticky tape or clips to hold in place.Commercial gel media is clean enough to have a minimal effect distortion-wise.
-Jeff
