Activity Forums Adobe After Effects Best Method for removing Noise with AE?
  • Best Method for removing Noise with AE?
    Posted by Aaron Poisson on January 20, 2011 at 4:46 am
    Hello,
    I have quite a bit of dark noisy footage to grade and part of that process requires me to de-noise. I have yet to find a total solution. I have AE CS4, I also have Red Giant’s Denoiser from Stabilizer and also one from Key Correct as well.
    I’ve attempted to find some tutorials on the remove grain filter that is bundled with AE, but can only find 3rd party plug-in tutorials.
    Any suggestions or points leading in the right direction is appreciated.
    Best Regards,
    Aaron Poisson
    Eyeris Productions
    https://www.eyerisproductions.com
    Cory Petkovsek replied 15 years, 7 months ago 3 Members · 4 Replies
  • Andrew Devis
    January 20, 2011 at 9:12 am
    Hi Aaron
    I know it’s another 3rd party plug-in but Neat Video is probably the best out there for noise reduction. In fact I am working on a tutorial now on noise reduction using some night shot dark footage with lots of noise.
    Once you have a good noise profile you can then save the profile for the camera in that mode and easily apply it and fine tune it to other clips shot with the same camera in the same mode with very little effort.
    Hope this helps
    Andrew
    … because it’s all about stories …
  • Aaron Poisson
    January 20, 2011 at 5:08 pm
    I saw your previous tutorial with your product, and it seems to be a very nice tool; however, we don’y have the budget to purchase any more software for some time.
  • Andrew Devis
    January 20, 2011 at 5:38 pm
    Hi Aaron
    I completely understand, it is hard to find the money for all these wonderful plug-ins! But when you have $99.90 for the pro version …
    All the best with your project
    Andrew
  • Cory Petkovsek
    January 21, 2011 at 12:15 am
    You can pass the footage through avisynth and use fft3d and/or grapesmoother and/or a variety of other noise reduction algorithms.
    However if this is for an employed position, you’ll quickly blow through $99 of employee time by learning how to use avisynth and plugins if you don’t already know how to use it. If you do, it’s a great tool for a variety of other aspects of post-production work. So if this isn’t an employed position, it may be worth your time to learn about it.
    I’d still start with the built in AE tools that Dave mentioned.
    Cory
    Cory Petkovsek
    Corporate Video
