Activity Forums Apple Final Cut Pro Legacy Best MacBook Pro for Final Cut Pro
  • Best MacBook Pro for Final Cut Pro
    Posted by Chris Green on June 28, 2012 at 4:11 pm
    Hi everyone.
    I have been using Final Cut Pro 7, and Final Cut Pro X for a while. I intend to get a new MacBook, well it will be my first MacBook because I do all of my work on an iMac.
    So, I wanted to ask what is the best option for MacBooks out right now and Final Cut Pro 7 and 10. It would be great if I could hear your opinions about the best option for both applications.
    My current choices in my head are between, 15in. 256gb SSD retina model with i7 and 8gb RAM, or 15in. 750GB model with i7 and 8gb RAM. I will be running all of my files from a USB 3.0 external drive.
    Sorry for such a personal and opinionated question, and thank you very much in advanced for your response.
    Ben Holmes replied 14 years, 2 months ago 3 Members · 2 Replies
  • Shane Ross
    June 28, 2012 at 5:18 pm
    Well, I have the 15″ 2.3Ghz i7 with 8GB of RAM, and it’s running circles around my MacPro:
    https://lfhd.net/2012/06/27/haunting-my-laptop/
    And this guy is running FCP-7 on the Retina MBP:
    https://forums.creativecow.net/thread/8/1161034
    Shane
    Little Frog Post
  • Ben Holmes
    June 30, 2012 at 11:54 am
    Speaking as ‘that guy’ I’d say it’s really a personal preference here.
    I’d go for 16gb ram for starters (not sure if that’s an option for the normal MBP) – I’ve found it makes a massive difference having more apps open – and you will see a benefit in FCPX.
    Beyond that, it depends on whether or not you prefer size over upgradability – either are fine machines, but I found the 512Gb flash drive (faster than the 256gb SSD I think) with the 2.6gb retina too good to miss. It means you can even store some broadcast-quality media for viewing/editing – something I’d never otherwise recommend. On the other hand, if you don’t care about the extra speed, you can fit a larger HDD in the standard MBP. Not sure I see the point of bumping up the cost of the standard MBP over the ‘standard’ Flash storage in the retina.
    One thing – I’d go thunderbolt for storage, over USB3 – although I use one for transfers to and from other computers.
    Either way – you’ll be happy.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
